Power Vision (dumb?) Question
Old Jan 19, 2014 | 11:35 PM
c-note's Avatar
c-note
Ok, PV it is! You guys deserve a commission.
Old Jan 20, 2014 | 12:37 AM
boosting1bar's Avatar
boosting1bar
You won't regret that choice, I've got a couple PVs for my bikes and love them. Buying from FuelMoto, as the others mentioned, gets you a tune for your bike that you can use to AutoTune and really dial it in for your particular set up. My bikes all have only minor upgrades (air cleaner, pipes, etc) so I've never really had any need for the AutoTune Pro, the Basic that device will do out of the box has always yielded good results.
The other big plus with the PV is any time you change a component it's as easy as plugging in your PV and doing a couple AT runs and you're tuned. That's great for those of us with ADHD who like to change pipes and/or air cleaners every few months lol
Old Jan 20, 2014 | 10:07 AM
JMC22's Avatar
JMC22
Thanks for all the advice here - I just pulled the trigger on PV myself and can't wait to have it arrive.
Question - I believe I read that you can store your original settings on the unit and revert back to it at any time by reflashing the ECU - is this a good thing to do prior to bringing the bike in for any warranty issues as HD can be a stickler at times if you don't use their stuff - IE: SEPST (not that I have any current issues, just asking for future knowledge)
Old Jan 20, 2014 | 10:12 AM
128auto's Avatar
128auto
Yes, it will save your original calibration automatically, you can also copy the current map. You can always go back to day one, no worries.
Old Jan 20, 2014 | 11:02 AM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Thank you very much for your order. We will get your Power Vision programmed and shipped today. If you need any product or tuning support we are just a call or email away.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old Jan 20, 2014 | 03:50 PM
ramhunter9's Avatar
ramhunter9
Great customer service ... ^^^
Best out Keep up the good work guys
Old Jan 20, 2014 | 09:08 PM
Gommee's Avatar
Gommee
Devil's Advocate
Ha, Ha, I just may take you up on that offer...Mine is getting installed in a week or two...
Old Jan 20, 2014 | 09:32 PM
izzyryder's Avatar
izzyryder
Originally Posted by 128auto
Auto-tune pro is definitely worth it, the wide band 18v oxygen sensor is the key. I have done 3 pro sessions and compare Fuelmoto A/B maps, dead on! You can always use PV alone with basic auto-tune and add AT pro later.
If you are using wide band auto tune you are better off with a power commander V that can make afr changes in real time. As far as I know, the Powervision cannot do this. It can only log the data, then has to wait for you to apply it. It doesn't do real time AFR changes based on sensor feedback to target afr values.
Old Jan 21, 2014 | 02:21 AM
slozomby's Avatar
slozomby
the stock ecu will automatically make small adjustments to afr on the fly once the table has been loaded from the power vision.
DavidStiebel
The Dyno Room
Nov 7, 2016 09:54 AM
heavyarms
Apr 6, 2015 08:54 PM
Toe Knee
Apr 18, 2011 03:00 AM
Keithhu
Jan 19, 2010 07:53 PM
rixida
Jun 25, 2009 11:57 AM
