Exhaust And Tuner Question.........
Looking to get a good Exhaust and tuner............Here's whats on the Bike now.
Stage 1 SE Air Intake.
FL-Xieds - 10.
As far as Exhaust goes can anyone tell me the big difference between 2 into 1 and 2 into 2 systems ??????
What is a good exhaust ?????
As far as tuner, I would be looking for reliability and ease of changing maps for future mods...........
Thanks..................
You'll get a bunch of different replies for the tuner. You need to do the research and decide what's best for you...don't just go by what the majority here will tell you. No matter what brand you choose..I would reccomend a tuner that reflashes the ECM and a tuner that you can adjust all aspects...not just fuel.
Good luck in your search.
FL-Xieds - 10.
. The basic autotune function on the PV is great for dialing in your tune on your own and doesn't really require much input at all from you.As for exhausts, there are a lot of options. I had the V&H 2-1 Comp series on my Fat Bob until I lowered the bike, then I didn't have enough ground clearance and had to change it out. It's still for sale in the classifieds if you decide you're interested in a 2-1. For 2-2 I think the Rinehart crossbacks look and sound awesome.
Tuner. .how far will you go? Don't fall into the hype for any "quick" or "easy" tuner. PowerVision w/ AutoTune is a good option because you can get a nice tune by yourself, and if ever needed, get a real tune by a tuner with the same module. Same goes for TTS, but a lot more research needed to use it properly.
