Cups/Raked Trees
Old Feb 1, 2014 | 08:57 AM
fxwoody's Avatar
fxwoody
When playing with rake and trail, the adjustments must be done properly if you don't want changing the handling of the bike.
OEM FXDWG 2012 specs : 34dg neck - Triple Clamp Offset 2.25" - Fork Length 33" - Triple Tree Rake 2dg. = trail 5.2"
Now if you go with same spec and add a 23" rim your trail should end up in the 4.34" range. Still good but affected handling a bit.
Your best bet would be a 37dg neck-2" trees and 2" over on tube to end up with 5.05" trail.
Anyhow, all this stuff can be calculated on this site : http://www.rbracing-rsr.com/rakeandtrail.html
Cheers
Old Feb 1, 2014 | 09:17 AM
CB024's Avatar
CB024
Cheers
Increasing the rim and tire size increases the trail. Going down to a 19" lowers it to 4.7
Old Feb 2, 2014 | 05:56 AM
mturner2003's Avatar
mturner2003
fxwoody thanks for the calculator link. In all the threads I've read, when someone posted a link to a calculator they were all dead now.
With that said, thanks for your input. Much appreciated.
Old Feb 3, 2014 | 06:14 AM
fxwoody's Avatar
fxwoody
Wink
You're welcome bud! I did had the same trouble when i raked mine last month loll
Old Feb 3, 2014 | 06:40 AM
mturner2003
According to that website, if I do stock wide glide trees and 3 degree cups, it will put me in Softail trail range. I'm comfortable with that.
KingTye
Dec 17, 2014 05:29 AM
Fat Chance
Jun 15, 2014 05:27 AM
jettchoppers69
Jan 7, 2013 09:46 PM
sothai
Dec 3, 2012 05:29 AM
deeblues
Feb 1, 2008 12:56 PM
