It was not easy but I was able to torque the engine bolts using the crowfoot wrench at 90 degrees. .with the frame and wheel in the way and not wanting to round off the bolt head. .wasn't fun. Having that oil filter out of the way would make that step 10x easier.
I'm so glad I decided to stop in and check the site today! I was just about to drop the money on a new Harley front mount. Now I'll just order this one instead! I've been waiting for word of this mount to hit.
Just one installation comment: This install was much easier using your motorcycle lift. You can easily remove the stock mount with the bike on the lift, without using a 2nd jack or any additional support of the motor, as your lift sits under it.
Then, when you are ready to install the new mount, lower your lift, place a small block of wood (i used a small square of plywood, 3/4 thick) between your lift and the motor. When you jack the bike back up...the motor moves up a bit higher because of the wood...and the mount slips right in.
Great photo! Your flange on the motor is different from an EVO motor. Even though the bolt pattern for the isolator to the flange is the same, the orientation of those bolts are very different. Now I can understand why you said it would be easier to remove the oil filter for torqueing. My bolts are to the outside and removing the oil filter does not do much for the EVO motor. Thanks for the information. I appreciate that and will feed that back to the engineer of this isolator.
Yea I didn't even think about that.. It wasn't too bad on the ground, the biggest thing was with the bike on the stand, the motor wanted to sag to the downhill side. I just had to take a pry bar, wrap it in a shop rag and pry it back to center to line up the frame bolts. Would have been much harder that way without a helper..
I took the bike to work today, traffic sucked so I couldn't ride very hard but I do have some feedback. I never had any huge complaints about vibration before the mount but I have noticed a reduction in high rpm vibration. Right around 2700-3k rpms there seems to be a little more vibration when cruising, but then again it could be from the smoother feel above and below that range. I was able to hit about 95 on a concrete portion of the freeway and the bike felt solid, no wallowing. The only other thing I've noticed is a quick and slight vibration in the right. peg when dropping a gear to pass and running over road turtles. I'm guessing it's just one of those things that sometimes comes with new parts and I'll get used to it. Hopefully I can get away this weekend and go hit some twistys, and I'll post on that
Do you know if that's kind of the same vibrations as people with the trutrack or sputhe?? I know I've read something like that in the past. Might not be the rubber portion, but more of the stabilizer?? I haven't had either, but when I get back from deployment I'm getting one of these mounts. Can't wait to read more feedback.
I believe so. The stabilizer link is designed to stop lateral movement of the motor which is what the others you mentioned do. The bonus is an improved mount that won't need replacement every 10k miles. I need to do more research on the rear mount since true track looks like they only sell the stabilizers as a kit, but I've heard the rear mount is a pretty good design. Anyone else have any input on that?
