Best 95" Kit
Old Feb 22, 2014 | 08:05 AM
mrlexus's Avatar
mrlexus
I did the Cyclerama 100/100 95" 'kit'. It does ok. He ported my stock heads, and it uses his cam grind. (If I remember right it's ground by Andrews). It's been going strong for quite a few years now. If I ever have the heads off, I would put in compression releases, I've toasted 2 starter gears before I finally put on the fancy heavy sprag version. (And both on trips) Once I changed the starter in Rapid City HDs parking lot, the other time I push started it and rode it 300 miles home without shutting it off.
Here it is with 2 different pipes, one a modified supertrapp (short megaphone). The other with rinehart staggered duals, with no baffles. (The baffles killed the top end, I'm talking 10hp) this is a carb engine.
PackN
Feb 26, 2018 12:08 PM
Jeffcruz
Nov 27, 2017 12:24 PM
beeker356
Dec 13, 2011 11:25 AM
mr-moen
Exhaust System Topics
282
Nov 24, 2008 11:11 AM
2006ultra
Oct 15, 2005 06:54 PM
