not getting fire on 01 fxdwg
Old Mar 21, 2007 | 12:02 PM
ltdano's Avatar
ltdano
1st Gear
Default not getting fire on 01 fxdwg
I have a 01 fxdwg that is not firing. I replace crank positon censor but still no fire. Could it be ignition module or cole?
Please Help
Old Mar 21, 2007 | 01:26 PM
mtnlvr's Avatar
mtnlvr
Default RE: not getting fire on 01 fxdwg
Do you have a service manual for the bike? If so, it does have troubleshooting in there for many electrical (and mechanincal) items.
Start simple...don't use the "replace everything until it works" method.
I'll usually check to make sure everything is getting power and ground before I start checking the individual components themselves.
I have electrical problems.
Old Mar 21, 2007 | 02:21 PM
DougsDyna's Avatar
DougsDyna
ORIGINAL: mtnlvr
I basically agree with the above. My manual for the 06 Dyna is pretty usless for troubleshooting.
Did your bike run okay, and then just suddenly fail?
Did it run okay, sit for a long time, and then not fire?
Has it been running like cr@p, and stop firing?
I would suggest spraying all the connections with contact cleaner, or WD40.
Clean and tighten up all your ground connections, etc.
The above can't hurt anything, and may save a lot of money.........
I agree that replacing parts is not the best way to go, and the wire(s)/connections you unplug to replace the part(s) may well have been the culprit in the first place.
Good luck
DougJ
Old Mar 23, 2007 | 04:38 PM
ltdano's Avatar
ltdano
1st Gear
the bike ran great, just quit all of a sudden.
Old Mar 23, 2007 | 11:03 PM
mtnlvr's Avatar
mtnlvr
You need a service manual or a trailer to take it to a shop or someone else.
There's too many things that can cause no spark.
Old Mar 24, 2007 | 07:24 AM
WdGldDave's Avatar
WdGldDave
Are you saying that the starter is working but the engine isn't firing? I'm assuming that you are getting battery power. Is that right?
Old Mar 24, 2007 | 12:33 PM
Craka05wideglide's Avatar
Craka05wideglide
I would suggest bringing it to a good mechanic...especially if you dont know how to use a multimeter. you could have a short and if u keep changing parts (coil, etc) your just tossin $ away...good luck man
Old Mar 27, 2007 | 05:03 PM
ltdano's Avatar
ltdano
1st Gear
I was riding bike and it just shut down. No fire to the engine. I bought a manualshowed me how to flash a code but the code is not in the manual.The code flashesthe security key and the check engine light 8 times.
please help.
Old Apr 9, 2007 | 10:59 AM
ltdano's Avatar
ltdano
1st Gear
FYI, I bought a manual and tracked the problem down to the Ignition module. Whos needs to pay $75an hourfor amechanic when you can fix it yourself.
Bryant91b
Jun 1, 2012 10:22 AM
SpiderPig
EVO
11
May 24, 2009 09:29 PM
csd4682
Ironhead
May 27, 2008 10:59 AM
electrafire
13
Jun 14, 2006 06:13 PM
Alia1200
General Topics/Tech Tips
Jun 26, 2005 07:17 PM
