How much is too much?
Old Mar 3, 2014 | 06:18 PM
target64's Avatar
target64
when I built mine the crank run out was .002 Scott from hillside told me there would be no issues with my crank on my 2011 . the first build stage II made 105/109 and I wailed the hell out of her for 10,000 miles with no issues. second time around now stage 4 this motor is wicked from the last build every time u grab a gear this thing is bouncing off the rev limiter instantly. only 300 miles on this build, time will tell but I have good faith it will last .
Old Mar 3, 2014 | 09:21 PM
HD Pilot's Avatar
HD Pilot
Originally Posted by rgr357
Understood, I have read about the tolerances required before going to a gear driven cam.
Haven't heard of it in terms of a general health check, but it stands to reason the further out the more susceptible you might be.
Not going to a gear driven cam, but Ill add it to my list of things to check, at least I will know for future work or reference. So are you saying, under a .006 would likely be ok? I thought the reason behind the bottom end work was to 1) fix the tolerances required for gear driven cams, 2) make it stronger so you dont twist or otherwise break things. which #2 is why I inquire.
Maybe I'm going about asking the question the wrong way. For those who have gone into the bottom end for the sake of pining and welding, what were the motivating factors?
Yeah, checking your run-out is not just for seeing if you can go gear driven cams or not, in my case I was planning my 107" build and had done a ton of reading and had determined that around .006" runout was the most I could feel safe that my build would not endanger my motor. Wouldn't you know it, I got a measurement at .0061". I was still somewhat tormented on whether to drop the $$ and effort to fix my crank/flywheels, but I decided to go ahead and fix it and now I am putting my motor back together.
A marginal runout number means that there is a higher risk that you could "scissor" the flywheels and pretty much ruin everything below the heads, some failures are worse than others. The biggest factors to consider are how big the engine build is, how aggressive you ride your bike and the runout number. There are no set in stone guidelines on what to do with this build and that runout, you just have to study and decide for yourself, I have told you what I think and I know there are others that would disagree - it is a little bit like buying insurance, maybe you need it maybe you don't.
Who knows, maybe you measure your runout and get a number like target64 and you will be good to go and no worries but if you don't check then your are taking an unnecessary risk. Maybe with mild bolt in cams and a Stage 1 with a not so aggressive rider you can skip the check but once you start talking about headwork, moderate cams, throttle body upgrades, etc now you really better do the check.
Old Mar 4, 2014 | 05:16 AM
target64's Avatar
target64
Alan u are exactly right any one doing any major upgrade should have the crank runout checked. when I did the maddghost's 107 he was also lucky his runout was very low. He is a very aggressive rider and cranks on his bike all the time, and has had no issues.
Old Mar 4, 2014 | 04:39 PM
maddghost's Avatar
maddghost
Checked yes but those cranks can take quite a bit of punishment out of the box. anything over .006 is getting dangerous but even then with a stage IV motor you have to wail continuously to pop it.
@ rgr357 All I ca suggest is don't go at it piece meal, you will wind up spending extra money and having parts collecting dust on a shelf. Get what you really want the first time so take your time and think it through. Also you will get better quality work done by a professional buider rather than spend money on HD's SE watered down performance.
Old Mar 4, 2014 | 07:48 PM
rgr357's Avatar
rgr357
Much appreciated!
A common theme to many of the posts on this & other sites are how someone did x last and will be doing y next to get more out of it. At the same time racking up $ going in and out of the build & parts lining up on the bench. Shoot I'm on my 2nd AC & sitting on some vance & hines 2-2 that sound great & look great, but stop there. Think Ill call it lesson learned and not just drop a 204 cam/SEPro on it.
For now Ill get the Feuling Crank run out tool on the way and start putting the pieces together; then engage Scott from Hillside. The SE Pro Stage IV is tempting at $1900 but I like the idea of really building to my riding preference and also like the TTS over the SEPro (that comes in the stage IV kit).
Crank run out will have a lot to do with the direction, hope I'm one of the lucky ones.
Old Mar 5, 2014 | 05:02 AM
maddghost's Avatar
maddghost
The SEpro tuner involves a dyno tuner and 4 - ? hours on the dyno and every time you change something significant a new tune.
The tts unless they have radically changed something is a little hard on the user aes you must 9or at least used to) ride around with a laptop recording data to create your next tune.
I would recommend the powervision for it's ease of use, just a few hours of reading up and you'll be tuning your bike on your own.
FTP ACAB
Milwaukee Eight (M8)
Mar 30, 2018 09:11 PM
bedelman10
Engine Mechanical Topics
98
Jul 21, 2016 07:00 PM
On Deck
Exhaust System Topics
11
Jul 16, 2011 09:29 AM
W0ace
Feb 27, 2011 11:36 AM
jkgraham
May 20, 2009 07:35 PM
