Would love to see the dyno print out for this...thinking of the same.
Looking around, this is the only dyno chart I can find for now.
Planning on doing some more work this fall. Sending out my heads and throttlebody to port and polish. Also going to try different air cleaner, do a different clutch and possibly thinking of changing up my cams.
Check with the guy that does your heads - I think new cams would be the right choice with the direction you are going. 583s have an intake close of 18 degrees(all low rpm and lower compression type cam)and with headwork you will have the great opportunity to raise compression and run much higher performing cams, maybe Andrews 54 or Genesis 577 or such.
Would be wise to check your crank run-out prior to dropping a ton of $$, might/might not change your plans.....
You will really notice the hp/tq change when you are done!
with set of good stage II heads and a set of S&S 585's set @ 10.8:1 and a SE 50mm tb will have you close to what u posted eariler. and it will be a huge difference over what you have now. it all depends what you want to spend. and the performance you want to gain.
Just finished a S&S 106 kit with S&S 583 EZ cams with a Thunder Max tuner. Dyno has me at 92hp/113tq. I was told to get rid of my SE heavy breather and put on a good 2 into 1 exhaust to get improvement. What next? Head work? If so, what should I do? What kind of numbers will I get on the dyno?
Did you add the S&S heads with that build?
I'd let her break in. I got 98/120 but I'm happy how she pulls and I never run out of throttle.
She's only 106 so I think I probably got all she has to offer but my *** Dino is still happy.
I have 25k on this build. Never a problem.
98/120 from the 106 is definitely not all that it has(impressive tq number for sure). An s&s 106 can definitely put do 120+ w/ right cam and most of all, heavy enough headwork.
Really? Ok...those s&s heads can still be worked your saying?
Sure those can be worked on. You didn't mention if you have new throttle body, so you can get the intake runners cut bigger to match (not sure what they come with stock), if you have the 79 cc heads the intake is 1.940 and exhaust is 1.575 (so that can be made bigger), and of course deck the heads to lower compression, wouldn't go to high for those 583's (not sure what u r at now).
A D&D 2:1 pipe and good tuner are also options for more grunt.
There are always possibilities, but all depend on $$$$$$$.
I'm real happy with my numbers but my build is suffering from the throttle body bottleneck (stock right now)...next time around gonna lower the compression a bit more and get the intake runners cut to 1.750 along w/ boring my SE 50mm tBody (sitting on the shelf waiting). Then will mostly likely change the roller rocker ratio as well like TARGET64.
still on fence about changing the cams(funding problems), if I do it will be 585s. will be sending out heads and trottlebody to s&s to port and polish.
