Some random Dyna questions.....
Old Mar 18, 2014 | 01:17 PM
bad93snake's Avatar
bad93snake
Originally Posted by C.J
Two little pads for 45 bucks was kind of annoying to me.
High cost for simple little parts annoying? Welcome to Harley ownership!
Old Mar 18, 2014 | 01:50 PM
Dynaglide68's Avatar
Dynaglide68
Beware of the IPB failing on your 1999 motor
Old Mar 18, 2014 | 02:18 PM
C.J's Avatar
C.J
What is the IPB?
Inner primary bearing.....sometimes it takes me a few minutes. Why is the 99 IPB an issue? Thanks for the heads up.
Old Mar 18, 2014 | 04:47 PM
NSCoyote's Avatar
NSCoyote
as ti was said about being annoyed at $45 brake pads, welcoem to Harley ownership LOL wait till you start doing in depth maintence and realize that what SHOULD cost $10 gets sold to us harley owners for $100
Old Mar 20, 2014 | 06:14 PM
missedem's Avatar
missedem
At least with a 99 motor you dont have to replace the cam chain tensioner shoes or have them checked every 20-30 K miles. Dyna's take some maintaining. Rubber engine mounts, brake pads, spark plugs, oil etc.
Old Mar 20, 2014 | 09:58 PM
stephenhelsel's Avatar
stephenhelsel
I just got my first twin cam HD, a 99 Dyna. Got my first ride in this past Saturday. Everything was mostly fine but I do have a couple of random questions that maybe someone can help answer for me......
I do have the HD manual....but it doesn't have all the answers.
1. When I pull the choke to start the bike when cold.....I have to hold the choke or it will return to the closed position. Is that normal operation?
2. The front brake light switch is a little slow to dis-engage. It comes on the moment I touch the lever but during (and after) my pre-ride function check.....it was slow to come off. Almost as if the switch was too close to the lever. Again, is this normal?
3. I paid 45.00 for a set of rear brake pads that are supposed to be the "bee's knees" and won't squeal or squeak.....well, of course they were squeaky when I applied the rear brake. I put them in dry, meaning no type of lube any where on the pad, caliper bracket or sliders. Should I dis-assemble and add some type of lube?
I also have a 99.
My choke did the same thing. Just had to to tighten up the adjuster on the backside. It is plastic so only do 1/4 turns at a time so u dont crack it like was mentioned before.
For the break squeal. It could also be your rotor is glazed. When I do brakes on my cars I always scuff the rotors up with sand paper and my DA sander. Havent had to change em on the dyna yet but will be doin the same when I do.
Old Mar 20, 2014 | 11:08 PM
Sharpie's Avatar
Sharpie
What kinda pads did you get that are the bees knees of pads? I just got Lyndall Gold Z pads but haven't installed them as of yet. I got them for stopping grip and because they are not suppose to generate brake dust. I'm tired of cleaning rusty brake dust from my chrome spokes. They were a lot more than $45 a pair.
Old Mar 21, 2014 | 03:29 PM
C.J's Avatar
C.J
I wasn't complaining about the price and I wish I could take back the "bee's knees" comment. I didn't think I'd get called out on it so many times....and I didn't mean to insult anyone else's brake pads. When I went to the indy and asked for rear pads he gave me DP Sintered Metal pads.... when they cost 45 bucks, I was like "these things are how much?" then he went into how they were worth it and practically guaranteed they'd never squeak.
flynavy
May 21, 2015 09:26 PM
HolyHandGrenade
Electrical/Lighting/Alarm
Aug 4, 2014 08:18 PM
BluBob
Sep 1, 2011 10:32 PM
bjewell
Aug 24, 2010 11:56 PM
king05
May 3, 2007 01:52 AM
