Help brake problem
Old Apr 30, 2007 | 07:32 PM
king05's Avatar
king05
Default Help brake problem
The brake light on my 05 road king is going on and off all on its own even if the bike is just sitting idling in the driveway. If I tap on the front brake lever it will go off for a second, then comes on again. Is there any adjustment in the switch that makes the brake light come on? I was thinking the switch ran off fluid pressure, not too sure though this is a new problem for me. I really dont want to take it to the dealer it has to be something simple(I hope), and i definatly dont want to get rearended. Thanx in advance for any fixes or even ideas of what the problem could be.
Old Apr 30, 2007 | 07:50 PM
Zimbob's Avatar
Zimbob
Default RE: Help brake problem
Have you done any work in the brakes lately? if so, you may want to retrace your steps. might want to try checking the sending(?)units.
Old Apr 30, 2007 | 07:56 PM
king05's Avatar
king05
Havent done anything to it this year but change the oil.
Old Apr 30, 2007 | 07:59 PM
Noble Steed's Avatar
Noble Steed
You may need to replace your rear brake pads. My RKC did the same thing when the pads got low. Do you have cruise control? It will not work if the brake light is on. The pads are only good for 6000-8000 miles, depending on your driving. I would start there. Good luck.
Old Apr 30, 2007 | 08:00 PM
glide's Avatar
glide
Could be a few things, first have you changed to chrome controls or had the brake handle off for maintenance of any kind. It could be the stoplight switch which is behind the brake lever causing the problem here. It is common for the tab that sticks out of the switch to be broken off when replacing the brake lever / master cylinder if you don't use something to hold the lever in the partially compressed position while replacing the cylinder or reinstalling the lever. It could also be the switch itself has moved out of position and the handlebar controls have to be opened up to reposition the switch. Either of these things will cause your problem.
Old May 2, 2007 | 07:42 PM
king05's Avatar
king05
Thanx glide u were right it was the switch. It was kinda a pain to replace but i'm sure i saved a little bit of cash doin it my self.
Old May 3, 2007 | 01:52 AM
choochoo's Avatar
choochoo
the front brake light switch is a mechanical button switch, does not
rely on fluid pressure to activate.
If you hand the right controls apart and didn't do it by the book (Card board
shim etc) you may have damaged the switch.
Or the switch just may be faulty.
Or handle assembly may be loose and vibrating enough when at idle to momentarily
activate the switch.
Guess you just have to inspect closer and see.
197rflores
Jun 13, 2024 03:27 PM
santajim
2014-2024 Touring Models
Apr 1, 2016 08:03 AM
HolyHandGrenade
Electrical/Lighting/Alarm
Aug 4, 2014 08:18 PM
Sportrider79
Apr 24, 2012 09:38 AM
roadking01
Oct 9, 2006 10:26 PM
