Front brake handle, loose, brake light comes on
Old Apr 24, 2012 | 12:19 AM
Sportrider79's Avatar
Sportrider79
Question Front brake handle, loose, brake light comes on
My front brake handle has a little slack in it so the brake light will come on if I barely touch it, seams to get better when I ride it but is there a way to tighten the lever up (push it out) I can see there is a spring behind it but I havent opened up the housing yet. not sure if this is a common issue,
Old Apr 24, 2012 | 07:47 AM
SportyPig's Avatar
SportyPig
Have you checked the brake line and fluid level? Sounds like you might have a small leak somewhere.
Old Apr 24, 2012 | 09:19 AM
Scuba10jdl's Avatar
Scuba10jdl
Do what SportyPig said, it's an easy check. The other thing it could be is thin brake pads. They make it so there is a bit more play in the lever. Finally, a master cylinder rebuild kit comes with a replacement spring, although my 10 year old spring is still fine.
Old Apr 24, 2012 | 09:38 AM
Sportrider79
I got new pads on order, I though about that later, with the pads worn it might give the lever a bit more slack, I just thought it was common since when you go down the road it tightens up and gets a whole lot better, (heat expansion?) dunno
Thumper26
Oct 28, 2015 11:17 AM
WVHogRider
Mar 27, 2012 08:05 AM
JustDave71
May 21, 2010 11:10 PM
roadking01
Oct 9, 2006 10:26 PM
RMXer
Apr 13, 2005 12:27 AM
