Forward install ?
Old Mar 26, 2007 | 12:01 PM
KC99JBS's Avatar
KC99JBS
Default Forward install ?
I bought forwards for my 07 Dyna. The kit is different from the earlier Dyna's.
I didn't want to pull off the inner and outer primaries so I ordered the shifter shaft cap and the bracket to hold the old shift rod to the motor case so it doesn't flop around.
These two pieces were from the earlier Dyna kit.
Question is this: when I back out the bolt in the motor case to mount the bracket, do I need to take it all the way out to reapply loctite? Or can I just back it out enough for the bracket and just re-tighten?
Also, does anyone know the torque for that bolt?
Thanks.
Old Mar 26, 2007 | 03:39 PM
jmbear328's Avatar
jmbear328
Default RE: Forward install ?
I just added forwards to my 06 Superglide and since I was installing a chrome inner and outter primary I just went ahead and put on the forwards then.As far as your install goes,... I'm unclear of just which bolt your talking about. Gimmie a lil better locoation and I'll look up the torque specs in my service manuel.
John
Old Mar 26, 2007 | 03:59 PM
KC99JBS's Avatar
KC99JBS
Is there exploded view type pics on here somewhere?
I just thought of something. How the hell did they torque my buddie's without removing the primaries?
Old Mar 26, 2007 | 10:06 PM
soup48's Avatar
soup48
Just remove the bolt part of the way and retighten it. I don't know the torque amount.
Old Mar 27, 2007 | 12:00 AM
TEXAS GHOSTRIDER's Avatar
TEXAS GHOSTRIDER
6th Gear
KC99......JUST BOUGHT AN 07 FXDC SUPER GLIDE CUSTOM LAST SATURDAY, WOULD LIKE TO ADD FORWARD CONTROLS ALSO, BUT THE HD DEALERSHIP WAS GOING TO CHARGE AROUND A THOUSAND BUCKS INCLUDING PARTS AND FOUR HOURS LABOR. THEY ALSO TOLD ME THE INNER AND OUTER PRIMARIES HAD TO BE REMOVED. ALSO WOULD LIKE ANY INPUT ON SOME AFTERMARKET PIPES, STOCK PIPES ARE WAY TO QUITE. LOOKED AT THE SCREAMIN EAGLE PIPES FOR THE 07, BUT TO BE HONEST THEY ARE REALLY UGLY AND DON'T SOUND MUCH BETTER THAN STOCK. THEY TOLD ME IN ORDER TO ADD ANY OTHER TYPE OF PIPES THE COMPUTER HAD TO BE CHANGED/REPROGRAMED OR WHAT EVER. AND AGAIN WAS LOOKING AT A COOL THOUSAND DOLLARS INCLUDING THE PIPES, COMPUTER AND LABOR. WHAT FORWARD CONTROL KIT DID YOU PURCHASE FOR YOURS? KEEP US UP TO DATE ON THIS.
Old Mar 27, 2007 | 12:18 AM
Matrix's Avatar
Matrix
Check this link out.....
https://www.hdforums.com/m_1004268/m...tm.htm#1004268
Old Mar 27, 2007 | 12:23 AM
Matrix's Avatar
Matrix
Here are a couple of pic of what I have done with the forward controls since......
[IMG]local://upfiles/13379/E4152D7CF4004AA787A3E6ECEA3F2A96.jpg[/IMG]
[IMG]local://upfiles/13379/751DB19A384B4C32A1012CA7754C3C6C.jpg[/IMG]
Old Mar 27, 2007 | 12:30 AM
surveyor's Avatar
surveyor
ORIGINAL: TEXAS GHOSTRIDER
Man your local HD dealer must really be a stealer. HD of Orange Park here in Jacksonville charged me $640 plus tax total. That is parts and labor.I did get 20% off the parts but a grand. Thats outrageous.
Old Mar 27, 2007 | 12:31 AM
Matrix's Avatar
Matrix
Mine cost me $295 shipping included. I installed them myself, real easy install. Kuryakyn brand standard length.
Old Mar 27, 2007 | 12:39 AM
mikec's Avatar
mikec
Why not get a sawsall with a good blade and cut the old
shifter shft from behind the inner primary cover. I know
I've read where others have done that on there's. Do a
search and see what comes up.
