Forward install ?
Old Mar 27, 2007 | 12:45 AM
Matrix's Avatar
Matrix
Default RE: Forward install ?
If I were to cut mine out I think that I would cut it by hand using a hack-saw blade as to not heat up the old shift shaft and cause damage to the gaskets between the primary covers.
Old Mar 27, 2007 | 12:48 AM
Matrix's Avatar
Matrix
The gaskets that I am refering to are between the inner and outer primary covers and form a sort of tunnel throughprimary coverswhere the existing shift shaft passes through.
Old Mar 27, 2007 | 12:52 AM
mikec's Avatar
mikec
Heat won't be a problem, lube the blade with cutting oil and go
slow.
captainhawg's Avatar
captainhawg
doing the full install isn't hard, we did it on my son-in-laws one evening.... I think you will be a lot happier in a month, than if you do the Mickey Mouse install....
Old Mar 27, 2007 | 01:05 AM
mikec's Avatar
mikec
I agree with that statement. With the tool for locking the sprockets, it
wouldnt be hard to do it the right way. I wouldn't want the mid shifter
on it, even if you could dress it up or hide it.
ORIGINAL: captainhawg
Old Mar 27, 2007 | 02:38 AM
WS6 Formula's Avatar
WS6 Formula
ORIGINAL: KC99JBS
I bought forwards for my 07 Dyna. The kit is different from the earlier Dyna's.
I didn't want to pull off the inner and outer primaries so I ordered the shifter shaft cap and the bracket to hold the old shift rod to the motor case so it doesn't flop around.
These two pieces were from the earlier Dyna kit.
Question is this: when I back out the bolt in the motor case to mount the bracket, do I need to take it all the way out to reapply loctite? Or can I just back it out enough for the bracket and just re-tighten?
Also, does anyone know the torque for that bolt?
Thanks.
Read these posts:
https://www.hdforums.com/m_576946/tm.htm
https://www.hdforums.com/m_1314832/tm.htm
Old Mar 28, 2007 | 07:17 PM
Psycho's Avatar
Psycho
ORIGINAL: Matrix
You worry too much.
Old Mar 28, 2007 | 10:51 PM
JayFromPa's Avatar
JayFromPa
ORIGINAL: TEXAS GHOSTRIDER
KC99......JUST BOUGHT AN 07 FXDC SUPER GLIDE CUSTOM LAST SATURDAY, WOULD LIKE TO ADD FORWARD CONTROLS ALSO, BUT THE HD DEALERSHIP WAS GOING TO CHARGE AROUND A THOUSAND BUCKS INCLUDING PARTS AND FOUR HOURS LABOR. THEY ALSO TOLD ME THE INNER AND OUTER PRIMARIES HAD TO BE REMOVED. ALSO WOULD LIKE ANY INPUT ON SOME AFTERMARKET PIPES, STOCK PIPES ARE WAY TO QUITE. LOOKED AT THE SCREAMIN EAGLE PIPES FOR THE 07, BUT TO BE HONEST THEY ARE REALLY UGLY AND DON'T SOUND MUCH BETTER THAN STOCK. THEY TOLD ME IN ORDER TO ADD ANY OTHER TYPE OF PIPES THE COMPUTER HAD TO BE CHANGED/REPROGRAMED OR WHAT EVER. AND AGAIN WAS LOOKING AT A COOL THOUSAND DOLLARS INCLUDING THE PIPES, COMPUTER AND LABOR. WHAT FORWARD CONTROL KIT DID YOU PURCHASE FOR YOURS? KEEP US UP TO DATE ON THIS.
A G for standard forwards? Wow, they saw you coming a mile away didn't they?
Burner1977
Jul 11, 2019 11:35 PM
flatsix
Mar 25, 2010 02:06 PM
Travlinman314
Mar 13, 2008 07:54 AM
jterp
May 11, 2007 08:33 PM
steamerz
Sep 21, 2005 07:00 PM
