Something ain't right......
Old Apr 15, 2014 | 11:44 PM
07bobber's Avatar
07bobber
Default Something ain't right......
Back in sept 2012 I dyno'd my 96" with woods tw6-6 cams ness big sucker and d&d fatcat (std baffle) the results were 93hp/98tq.
I thought these numbers were fantastic for just cams pipes etc
Since then I've added a revolution cycles 106 big bore kit and minor headwork done by wink eller.
today I finally had my bike dyno tuned. The results to say the least were disappointing.
95hp/105tq
Idk what went wrong these numbers are way too low.
Old Apr 16, 2014 | 02:01 AM
ebeattie's Avatar
ebeattie
What was the compression ratio on the pistons installed with the kit? Also, headwork to the combustion chamber will lower the compression ratio futher. If just porting the runners, shouldn't affect it. Ive talked to Fuelmoto about cams an ALOT of the woods cams beyond the Tw-222 and Tw-555 NEED higher compression to get the most benefit of the cams. 10.5:1 was the ratio that seemed to be most relevant.
Old Apr 16, 2014 | 07:14 AM
24v's Avatar
24v
Stupid question....Did you have the bike dynoed both times at the same place? If so, were they using the same correction? (i.e. sae, std, etc)
Old Apr 16, 2014 | 07:45 AM
07bobber's Avatar
07bobber
The combustion chamber wasn't touched, the ports were cleaned up (light headwork). The kit is supposed to be 10:1 and the head gasket was .040" should of went .030
Old Apr 16, 2014 | 07:48 AM
07bobber's Avatar
07bobber
Yes the dyno was done by the same shop, the dyno sheet says correction is STD
Old Apr 16, 2014 | 09:04 AM
128auto's Avatar
128auto
Sorry to hear that. Yeah, you are right, not impressive at all. With headwork, you got to pass the 100 mark.
That's why I like to get parts from one developer, at least they know what a good combination is. I don't know what else to say
95hp/105tq
Old Apr 16, 2014 | 09:13 AM
PaiN's Avatar
PaiN
106 kit? ...Maybe its true, "size ain't everything" ....... na
Old Apr 16, 2014 | 01:56 PM
07bobber's Avatar
07bobber
So I talked to the mfr of the big bore kit, and he thinks the kit either isn't broke in all the way (BS imo) or because the springs in the heads are robbing power because the were set up to run up to .600 lift.
Im gonna tear down the motor after Laughlin...
Old Apr 16, 2014 | 03:29 PM
HD Pilot's Avatar
HD Pilot
Yeah I don't buy either of those either. Have you calculated the compression ratio using the Big Boyz Calculator? You will need deck height and other info. Most stock deck heights are around .008" in the hole and if you add a .040" head gasket then the quench is getting too big. A .030" or .027" should help you get the compression up - let me know if you need some .027" Cometic hgs.
Old Apr 16, 2014 | 04:12 PM
07bobber's Avatar
07bobber
I did use their calculator and the compression is supposed to be around 185, I checked compression and I think the gauge was bad since it gave the same reading on 3 different bikes (115 psi) and I haven't checked it since.
I checked deck height and it was around .010
once I get her apart im gonna recheck everything and ill get back at you for gaskets, I might as well get the heads decked while im at it...
