Something ain't right......
Old Apr 16, 2014 | 06:38 PM
bdtaylor1979's Avatar
bdtaylor1979
Yeah, that don't sound right. You would think you would get more than 2hp more going up 10 cubic inches.
Old May 19, 2014 | 09:57 AM
07bobber's Avatar
07bobber
ok so I got the engine apart this weekend, both piston had some blowby but the rear was worse......I probably didn't set the orientations of the rings right...FML
anyways gonna order new rings and start cleaning up everything and try to do this right the second time around..
Old May 19, 2014 | 11:05 AM
203Cree's Avatar
203Cree
Don't forget to have the jugs bore honed again.
Old May 19, 2014 | 11:48 AM
HD Pilot's Avatar
HD Pilot
Those Woods 6-6 are pretty small for a 106" with headwork. I would for sure up the ante in the cam selection. The .027" Cometics will help with the compression and allow for better cams too. Not sure where you want your cams to excel but Woods 555, Andrews 54, Genesis 577 all come to mind.
Are you still running a stock throttle body(46mm)? There are a couple of places that can modify your stock tb and really help you on the higher rpms - Dan Vance Racing, maybe?
Old May 19, 2014 | 12:39 PM
JRK5892's Avatar
JRK5892
we can P&P your TB, we actually stock one for exchange
Old May 19, 2014 | 02:52 PM
Slvr764's Avatar
Slvr764
This is the way to go! I did this a couple years ago and was very pleased with the turn around.
Old May 19, 2014 | 07:10 PM
HD Bobber's Avatar
HD Bobber
Damn dude feel your pain. Looking forward to see how everything turns out and how the HP will be much higher next time you hit the dyno. It will work out just fine.
Old May 19, 2014 | 07:16 PM
128auto's Avatar
128auto
Did you check/set the ring gap in the first place? That is very important imao.
Old May 19, 2014 | 09:14 PM
203Cree's Avatar
203Cree
If he bought it as a kit, the end gap should've been set when he got it. Should've.
mrsnipy
Mar 8, 2019 10:45 AM
hattitude
May 17, 2016 08:17 PM
ghoticov
Jan 22, 2014 12:07 AM
jmb79
Oct 21, 2013 08:30 PM
jmxp
Jul 12, 2008 03:47 PM
