Ignition/lock switch removal...?
Old Apr 20, 2014 | 10:17 PM
loopie's Avatar
loopie
WHY you asked how????,,, I told you how you don't need any special tools, it takes about 2 minutes to remove it using basic tools, you could even use 2 nails and a screw driver, Not every job needs special tools,.. up too you but maybe take it too a dealer, its very easy with basic tools too remove your choice, be rideing today or awaiting that TOOL you don't need, I would rather off said thanks loopie im out rideing today
Old May 18, 2015 | 06:42 PM
Robbysride's Avatar
Robbysride
I used needle nose pliers this weekend. Stick the ends in two of the holes and the use a large crescent wrench on the pliers to turn it. Make sure to unplug the plastic plug on the fork locking pin thats located under the fork tube. Then just be careful pulling the ignition switch out.
dyna rider
Milwaukee Eight (M8)
Oct 30, 2016 11:21 AM
Gliden
Jan 2, 2012 04:23 PM
citytrucker26
EVO
17
Jun 15, 2010 10:26 AM
WWallstev
Aug 20, 2008 09:16 PM
rewog
Jun 30, 2007 01:19 PM
