Clutch basket
Old Apr 21, 2014 | 06:24 PM
mademoney101's Avatar
mademoney101
6th Gear
Default Clutch basket
Do i need to spend the money on a billet clutch basket for my 120r?
Old Apr 21, 2014 | 06:42 PM
skinman13's Avatar
skinman13
yes you will have to spend money...unless you are a hot babe looking to trade sweet stuff for parts...
Old Apr 21, 2014 | 07:37 PM
HD Pilot's Avatar
HD Pilot
If I got this right, you are putting a 120 into a FatBob with its' stock clutch? I have the stock clutch with a Barnett HD spring and it slips on my 107 build. I think you will need a new clutch like the Bandit Sportsman to handle the 120. I am just going to change out the frictions/steel plates but that is probably not enough for you.
OK, kinda slow today - Clutch BASKET, sorry no help here, have not heard much at all about replacing the basket.
Old Apr 21, 2014 | 09:13 PM
vdop's Avatar
vdop
Yes, cheap insurance.
Old Apr 22, 2014 | 08:14 AM
HD Bobber's Avatar
HD Bobber
You can blow your clutch basket on a 106 (father in law did that on his RG Stroker 106).......that being said I personally would get a complete basket and clutch setup ($1,100), but it also depends how hard you ride.
It's the hole shots that put all the major bottom end stress and where the stock unit will most likely blow.
When his basket blew it shot straight back to the back of the primary case then just rattled around inside, not causing any more damage, most importantly didn't lock anything up while he was blasting down the strip!
Old Apr 22, 2014 | 11:27 AM
hell hound's Avatar
hell hound
Wow, i guess i have never heard of that happening, to be honest i thought it would just slip or burn up or maybe even not release if the basket was damaged. That sucks!
Old Apr 22, 2014 | 11:33 AM
parts eeter's Avatar
parts eeter
Would the Barnett Scorpion setup work here? Just googled, you dont get the basket.........
The basket is seperate purchase
http://www.barnettclutches.com/1850/...cessories.html
Old Apr 22, 2014 | 12:24 PM
HD Bobber's Avatar
HD Bobber
$670 Evolution Basket
• 46-tooth
• Forged 6061 hard anodized aluminum two-piece clutch basket
• Includes bearing, steel sprocket and ring gear
• Raises RPM to achieve maximum performance eliminating lugging of motor
• 2 pounds lighter than stock
• Accepts stock replacement clutch pack or Evolution Industries Stage 1 or Series D performance clutch
• 3 year limited warranty
http://www.jpcycles.com/product/631-064
lee123
Oct 26, 2019 08:39 AM
D W K
Sep 29, 2014 07:59 AM
Mxtweeker
Jun 27, 2010 12:36 PM
Barrenmug
Mar 8, 2010 07:48 PM
tgaetto
May 1, 2008 04:15 PM
