Tire Pressures
Old Mar 28, 2007 | 03:12 AM
docsg's Avatar
docsg
Default Tire Pressures
I have an 05' FXDLI and just recently had the dealer mount a set of Metzler 880's. I have looked all over their web site but am unable to find the correct pressure to run. I currently run 40 psi in the rear and 39 psi in the front. Is this correct or is there a more optimal pressure to run? Thanks for your help--
Old Mar 28, 2007 | 09:58 AM
murphdog's Avatar
murphdog
Default RE: Tire Pressures
Look on the US metzeler website. On the front page they have both full line brochure and V-Twin upgrades manuals you can look at or download. Front min/max is 38/42. Rear min/max is 40/42.
http://www.us.metzelermoto.com/
Old Mar 30, 2007 | 11:04 PM
docsg's Avatar
docsg
ORIGINAL: murphdog
Thanks--I downloaded the upgrade literature. Seems I'm right in the numbers. Is it normal for the tires to lose a couple of pounds pressure when the bike sits for a week or so? They are tubed on wire rims.
Old Mar 31, 2007 | 01:03 AM
phreak's Avatar
phreak
yeah it is normal phor tubed tires on spokes to lose a small amount of air. in phact I think even tubeless will lose a bit.
I am still running Dunlops, and even though the sidewall has a higher number, I'm running 30 up phront, and 36 in the rear.
Old Mar 31, 2007 | 10:02 AM
DougsDyna's Avatar
DougsDyna
Tire pressure....................... ALWAYS check your tire pressure.
Believe it or not, you could lose several lbs. of air overnight.
I check my tire pressure before every ride, right after I check the oil.
IMO
DougJ (not Bob)
ScooterJammer
Mar 30, 2018 05:54 AM
RaceFace
Jun 30, 2013 04:35 PM
WVleo
Aug 23, 2008 09:25 PM
OldBoldPilot
Feb 8, 2008 12:29 PM
Kern
Aug 11, 2007 02:09 PM
