dyna clunk
Old May 5, 2014 | 07:08 AM
skinman13's Avatar
skinman13
If it were me, I would loosen up the lower fork pinch bolts a few turns and then retorque them...then look at the gap on the light clamps...if you do not have any gap, it could be that you are as tight as you can get but the clamps are not clamped tight on the tubes...could be stretched.
Good luck and let us know how it goes...
Old May 5, 2014 | 07:16 AM
customglide57's Avatar
customglide57
i'll give it a shot and hope for the best. should've just bought a manual and done it all myself. tks,
Old May 5, 2014 | 07:18 AM
Warp Factor's Avatar
Warp Factor
I agree. And if the light clamps won't tighten any more, you could try shimming them with a turn or two of tape underneath.
Old May 5, 2014 | 10:30 PM
jangler14's Avatar
jangler14
Is the wiring for the signals binding when turning all the way to one side thereby pulling your signals out of position? Like maybe when turning the front to the left? Just throwing out ideas here.
Old May 5, 2014 | 10:33 PM
103 sedona orange's Avatar
103 sedona orange
Take it back to the Indy.
Old May 6, 2014 | 05:33 AM
customglide57
not going to take it back to him. don't trust him now. I loosened the lower cinch bolts and gave the forks a couple whacks with a deadblow and tightened things up. will go for a ride after I get done work here in the woodshop today and see what happens. tks,
Old May 7, 2014 | 05:52 AM
customglide57
loosening the lower cinch bolts and retightening them I think did the trick. rode about 50 miles yesterday evening and things seem to be ok. now to tear the front end apart and put new springs and in!! bike is almost 15 years old and with less than 13,000 miles it's probably time to change some things. thanks to all for the advice.
Old May 7, 2014 | 06:40 AM
vaxxine's Avatar
vaxxine
5th Gear
Try making a witness mark on one of the tubes and the tree - pencil or dry erase marker. That'll tell you if the tube is rotating. I'm having a hard time imagining the tube being able to rotate without all sorts of other problems being apparent.
clap
Jun 1, 2014 04:29 PM
Rawhide68
Electrical/Lighting/Alarm
Oct 6, 2013 09:05 AM
pikeysxtcob
Jul 15, 2013 08:00 PM
ZeroThoughts
Jul 12, 2013 09:04 PM
dlkeneipp
Sep 22, 2007 03:10 PM
