Dyna TSSM
Old May 23, 2014 | 10:54 AM
HDeuce's Avatar
HDeuce
Default Dyna TSSM
Does anyone know where the TSSM (turn signal security module) is on a 2002 cvo dyna wide glide? My dad has one and the turn signals flash randomly and a HD tech said the TSSM module was bad but we can't find it. I have a 2005 softball deuce and my service manual shows mine behind the inner fender. I didn't know if it would be different on a dyna before we tore into it. Thanks.
Old May 23, 2014 | 12:58 PM
Mr Bentwrench's Avatar
Mr Bentwrench
On my 2007 FXDL it was behind the ignition cover on the lower left behind the coil. You only see the square end of it and when you pull it out, its long with two wire harnesses plugged into the end . My TSM only used the larger of the two plugs. Guess the smaller was the alarm part of my original TSSM.
YMMV
Old May 23, 2014 | 09:38 PM
HDeuce's Avatar
HDeuce
YMMV
Thanks for the info and a place to start looking. Better than behind the inner fender!
Oldman - New Iron
Dec 3, 2014 10:33 PM
scabmachine
EVO
May 20, 2013 07:35 PM
bikeme2001
May 28, 2012 07:36 PM
t-sport
Mar 2, 2012 08:10 AM
06dynamarine
Jun 19, 2011 09:09 PM
