changing gears without clutch
Old May 26, 2014 | 03:44 PM
Warp Factor's Avatar
Warp Factor
Originally Posted by kreeess
funny this thread popped up, yesterday on my way home I accidentally rev matched and switched to 6th gear without clutch... I was distracted trying to look at the filter that had fallen off my bike on the fwy that I accidentally switched gears without clutch (Sportbike instinct)... I rev matched and it didnt sound like i messed anything up, so it IS possible
Nope, you didn't rev-match between 5th and 6th. It might be possible to do it between first and second with a neutral in between, but not between 5th and 6th.
Motorcycle transmissions are basically what we used to call a "crashbox" in a racing car. No synchros, no neutral between gears, and no possibility of rev matching. You just crash the next gear.
Old May 26, 2014 | 03:47 PM
kreeess's Avatar
kreeess
Originally Posted by motolocopat
A little pressure on the shifter and back of the throttle should pop right into the next gear when it hits synchronous speed....shifting up shifting down, not recommended
Like this...
Old May 26, 2014 | 03:50 PM
Von_Zipper's Avatar
Von_Zipper
I remember on of such discussions from past, I tried to explain how things work until some of those wannabe pundits chimed in letting me know motorcycles have constant mesh transmissions and no synchro nor clutch is needed.
Old May 26, 2014 | 03:58 PM
kreeess's Avatar
kreeess
Hmm idk if I agree with that.. Clutch is definitely needed IMO ... I'm no pro but that just sounds so sketchy switching gears without a clutch all the time.
Old May 26, 2014 | 05:14 PM
mud's Avatar
mud
Originally Posted by Killer Bee19
Is this some thing that should be able to be done with our bikes? recently installed a new clutch cable just noticed that I can Change gears without clutch. wondering if I did something wrong.
myownself, I do not recommend it.
kills the dogs.
I know this from personal experience.
did it for a while. it was great. almost like shifting with an automatic trans.
**** hit the fan.
pulled the trans assembly out.
stopped counting at 400 bux damage.
guy at the shop had a used trans for 400.
slid it in and back on the road..............
babaharley
Oct 3, 2017 09:00 PM
Oldsarge29
Oct 28, 2012 11:07 PM
bigredwing
Sep 1, 2011 11:00 AM
flyboyjacko
Sep 15, 2007 04:59 PM
wolf1477
Ironhead
Jan 16, 2007 04:23 AM
