Removable Super glide key
Old May 30, 2014 | 02:08 PM
Chaddilac's Avatar
Chaddilac
Default Removable Super glide key
Hey guys I have an 06 fxdi and I have a couple of questions the first is has anyone ever smoothed the notch off of the barrel key so that you could remove it after it is switched on? And the second does anyone know if it is possible to parade to the smartII system from 07 with the proximity fob thank you all
Old May 30, 2014 | 03:25 PM
bobnehoc's Avatar
bobnehoc
Grind the knub off the key will make it removable. Did on my 08 SB and my 07 LR. Not sure about your other question but I am sure someone else will chime in.
Old May 31, 2014 | 06:35 PM
Chaddilac's Avatar
Chaddilac
It looks like all the connections are the same I wonder if there is a difference in the ECM
Old May 31, 2014 | 08:32 PM
Jonesee's Avatar
Jonesee
If you remove the key with the ignition on then use the kill switch, your light will remain on.
Great idea for about 45 minutes, then it really sucks.
Old May 31, 2014 | 11:27 PM
Chaddilac's Avatar
Chaddilac
Call me silly but after building a completely custom dyna I think a key and fob looks tacky hanging from the neck tube when the ignition is on
Old Jun 1, 2014 | 07:42 AM
Kazz's Avatar
Kazz
The new bikes have a hidden key system that is under a flip up cover on the tank ignition switch.
You just unlock the switch and pull the key out. It works great. I love being able to just walk up to the bike ( with fob in pocket) and start it up.
The alarm won't allow the lights or anything else to turn on with out the fob or pin being entered.
HDConvertible
Apr 14, 2021 11:32 AM
Griff012FLHX
Sep 28, 2017 10:03 AM
Temporary Username 1
Nov 27, 2013 08:27 PM
freak
Jan 24, 2011 03:37 PM
gregbenner
Feb 17, 2009 09:27 PM
