Battery keeps going dead
Old Oct 29, 2014 | 05:56 PM
128auto's Avatar
128auto
You need a Caravan charging system to feed your accessories just kiddn
You may want to read this http://blog.jpcycles.com/step-by-ste...arging-system/
Old Oct 29, 2014 | 07:03 PM
skinman13's Avatar
skinman13
Originally Posted by WhiskeyHarley
Alright so I took off my radio, I tested the stator (before it went to the regulator) It's getting like 20 or so volts at idle 26 with some gas, and (while running) I tested the spot at the circut breaker where the regulator goes and it's at 12.3 volts, battery reads the same. Is that low? Is the regulator shot?
You should read 30-40 vac @ 2000 rpm minimum across the stator connector with the voltage regulator disconnected.
12.3 vdc at the regulator output is too low even for a fully charged battery. My bet is that is what you will read across the battery terminals as well which indicates that your voltage regulator has done gone **** up. There is a very good probability that you have overloaded the voltage regulator with too much electrical load connected and a new VR or your stator...or both...will soon give it up also...
Someone else here will have to tell you if there is a charging system available that will handle the load you are placing on it...I don't know of one.
klimoman
Audio Systems
11
May 27, 2018 06:11 AM
Budda109
Audio Systems
14
Jul 27, 2016 07:05 PM
Jetjunkie
Oct 22, 2013 12:52 PM
Rauzer
Aug 11, 2012 05:15 AM
fxrtfan
EVO
13
Aug 20, 2011 05:31 PM
