Help
Old Jun 26, 2014 | 08:54 PM
stbobshadow's Avatar
stbobshadow
Default Help
Started to crank my 06street bob and it started back firing and barley ran and shut off. Changed the plugs and wires and still won't stay running but a few seconds and real rough while it does. What's the next step coil? Crank position sensor?
Old Jun 26, 2014 | 09:01 PM
SuperFastGlide's Avatar
SuperFastGlide
check for codes?
Old Jun 26, 2014 | 09:04 PM
stbobshadow
How can I check the codes
Old Jun 26, 2014 | 09:16 PM
jpicht's Avatar
jpicht
Try this thread:
https://www.hdforums.com/forum/ignit...tic-codes.html
Old Jun 26, 2014 | 09:35 PM
stbobshadow
Ok found P0131 front oxygen sensor low
P0373 ckp sensor intermittent
P1353 front cylinder no combustion
Leaning toward cKP but would that cause no combustion in the front cylinder?
Old Jun 27, 2014 | 08:15 AM
WMX124's Avatar
WMX124
I think the crank position sensor tells the spark plus when to fire based on the crank position. So it would make sense that when the sensor goes, you could have intermittent combustion in one or both cylinders.
emnnitetrain
14
Oct 1, 2013 11:49 PM
Chap
Apr 22, 2012 09:26 AM
BYRDNUTZ
Sep 9, 2011 07:18 AM
2001electra
Mar 8, 2010 10:19 PM
huey408
Nov 10, 2009 04:18 PM
