Desperate Help Needed !!! DynoJet
Old Apr 4, 2007 | 02:47 PM
Bobber M's Avatar
Bobber M
2nd Gear
Default Desperate Help Needed !!! DynoJet
Hi Guys,
I have dropped the bike into Harley today for stage1 , all was going well until the instalation of the DynoJet Power commander PCIII.
The dealer had not fitted one before !!! and the computer is showing two faults :
Exhaust actuator error P1475 and
Intake solenoid low/open P0661.
Now the dynojet software is showing everything OK , however the HD software is showing the 2 faults and the Engine management light is staying On.
Can anybody Please help , my bike is at the dealers with all the mech,s scratching their Heads.
-=BobberM=-
Old Apr 4, 2007 | 03:01 PM
hd_sob's Avatar
hd_sob
Default RE: Desperate Help Needed !!! DynoJet
I'm guessing you need to clear those codes and see if they come back. Do they know how to do that?
Old Apr 4, 2007 | 03:03 PM
hd_sob's Avatar
hd_sob
01 - Turn ignition switch to OFF & Run/Stop switch to RUN.
02 - Push odometer reset button in & HOLD.
03 - Turn ignition switch to IGNITION and release odometer reset button. Background lighting should illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word “diag” should then appear.
04 - Push the odometer reset button once and you will see the selection menu:
'PSSPt' with the first 'P' flashing.
05 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you want to check. To move from one letter (module) to the next, you push the odometer reset button one time.
P = ECM/ICM S = TSM/TSSM (Turn Signal/Turn Signal Security Module)
SP = Speedometer
t = Tachometer
06 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTCs, the code will be displayed or the word “none” will appear. Push the odometer reset button again to view additional codes if they exist.
07 - Record the codes.
08 - If there are no DTCs to be cleared, press and release the odometer reset button. Part number of module will be displayed. NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button (longer than 5 seconds) until 'clear' is displayed.
Release the odometer reset button. Turn OFF the ignition switch. Run the bike and shut it down, then recheck the DTCs again by repeating steps 1 - 9. If the code is current it will reappear.
09 - Press and release the odometer reset button to continue to the next module.
10 - Turn Ignition switch to OFF.
Old Apr 4, 2007 | 03:06 PM
DenimStreet's Avatar
DenimStreet
Where else can you get an answer like that? You gotta love this forum!!![sm=hail.gif]
Old Apr 4, 2007 | 03:09 PM
Bobber M's Avatar
Bobber M
2nd Gear
Keep them answers coming guys , really appreciate the replies.
Bobber M
Old Apr 4, 2007 | 03:18 PM
Geronimo's Avatar
Geronimo
Not for nuttin' but HOW did you know the codes? are they in the service manuals (I have a SM but have not had a need to even look for them)? if yes, how would someone know what the error codes were that were causing the "Oh CRAP!" light to come on? Is there diagnostic software available? just curious.
Just looking to pick up a ting or two?
Old Apr 4, 2007 | 03:21 PM
hd_sob's Avatar
hd_sob
FAULT CODES:
B0563 Battery Voltage High TSM/TSSM
B1004 Fuel Level Sending Unit Low Instruments
B1005 Fuel Level Sending Unit High/Open Instruments
B1006 Accessory Line Overvoltage Instruments
B1007 Ignition Line Overvoltage Instruments
B1008 Reset Switch Closed Instruments
B1131 Alarm Output Low TSM/TSSM
B1132 Alarm Output High TSM/TSSM
B1134 Starter Output High TSM/TSSM
B1135 Accelerometer Fault TSM/TSSM
B1151 Sidecar BAS Low TSM/TSSM
B1152 Sidecar BAS High TSM/TSSM
B1153 Sidecar BAS Out of Range TSM/TSSM
P0106 MAP Sensor Rate of Range Error Carb
P0107 Map Sensor Failed Open/Low Carb
P0107 Map Sensor Open/Low EFI
P0108 Map Sensor Failed High Carb
P0108 Map Sensor High EFI
P0112 IAT Sensor Voltage Low EFI
P0113 IAT Sensor Voltage Open/High EFI
P0117 ET Sensor Voltage Low EFI
P0118 ET Sensor Voltage Open/High EFI
P0122 TP Sensor Open/Low EFI
P0123 TP Sensor High EFI
P0261 Front Injector Open/Low EFI
P0262 Front Injector High EFI
P0263 Rear Injector Open/Low EFI
P0264 Rear Injector High EFI
P0373 CKP Sensor Intermittent Carb
P0373 CKP Sensor Intermittent EFI
P0374 CKP Sensor Not Detected Carb
P0374 CKP Sensor Synch Error EFI
P0501 VSS Low Carb
P0501 VSS Low EFI
P0502 VSS High/Open Carb
P0502 VSS High/Open EFI
P0505 Loss of Idle Sped Control EFI
P0562 Battery Voltage Low Carb
P0562 Battery Voltage Low EFI
P0563 Battery Voltage High Carb
P0563 Battery Voltage High EFI
P0602 Calibration Memory Error Carb
P0603 EEPROM Failure Carb
P0603 ECM EEPROM Error EFI
P0604 RAM Failure Carb
P0605 Program Memory Error Carb
P0605 ECM Flash Error EFI
P0607 Converter Error Carb
P1001 System Relay Coil Open/Low EFI
P1002 System relay Coil High/Shorted EFI
P1003 System relay Contacts Open EFI
P1004 System Relay Contacts Closed EFI
P1009 Incorrect Password Carb
P1009 Incorrect Password EFI
P1010 Missing Password Carb
P1010 Missing Password EFI
P1351 Front Ignition Open/Low Carb
P1351 Front Ignition Open/Low EFI
P1352 Front Ignition Coil High/Shorted Carb
P1352 Front Ignition Coil High/Shorted EFI
P1353 Front Cylinder No Combustion EFI
P1354 Rear Ignition Coil Open/Low Carb
P1354 Rear Ignition Coil Open/Low EFI
P1355 Rear Ignition Coil High/Shorted Carb
P1355 Rear Ignition Coil High/Shorted EFI
P1356 Rear Cylinder No Combustion EFI
P1357 Intermittent Secondary Front EFI
P1358 Intermittent Secondary Rear EFI
U1016 Loss of ICM/ECM Serial Data Instruments
U1016 Loss of ECM Serial Data, Vehicle Speed, Vehicle Inhibit Motion or Powertrain Security Status
U1064 Loss of TSM/TSSM Serial Data Carb
U1064 Loss of TSM/TSSM Serial Data EFI
U1064 Loss of TSM/TSSM Serial Data Instruments
U1097 Loss of Speedometer Serial data Carb
U1097 Loss of Speedometer Serial data EFI
U1097 Loss of Speedometer Serial data TSM/TSSM
U1255 Missing Message at Speedometer EFI
U1255 Serial Data Error/Missing Message EFI
U1255 Serial Data Error/Missing Message Instruments
U1255 Serial Data Error/Missing Message TSM/TSSM
U1300 Serial Data Low Carb
U1300 Serial Data Low EFI
U1300 Serial Data Low Instruments
U1300 Serial Data Low TSM/TSSM
U1301 Serial Data Open/High Carb
U1301 Serial Data Open/High EFI
U1301 Serial Data Open/High Instruments
U1301 Serial Data Open/High TSM/TSSM 2006 models with 02 Sensors (Dynas)
P0131 Front 02 sensor lean for any length of time
P0151 Rear 02 sensor lean for any length of time Above codes can also be set if 02 sensor fails.
Old Apr 4, 2007 | 03:34 PM
Bobber M's Avatar
Bobber M
2nd Gear
hd_sob ,
Mines a 2007 bob does it make a difference or are the codes the same bud ?
-=Bobber M=-
Old Apr 4, 2007 | 04:09 PM
hd_sob's Avatar
hd_sob
Dunno, maybe different if the ECM changed. Honestly, couldn't tell ya...
Old Apr 4, 2007 | 05:06 PM
Geronimo's Avatar
Geronimo
so how would someone know what the error codes were that were causing the "Oh CRAP!" light to come on? Is there diagnostic software available? just curious.
