Starter motor recommendation
Old 10-23-2014, 05:44 AM
Warp Factor's Avatar
Warp Factor
Warp Factor is offline
Originally Posted by 128auto
This starting problem is hit and miss, 8 out of 10 start fine. Sometimes I ride only 20 mins, shut the motor off and try to start it, it feels like the starter works so hard. If I don't start it the first 2 revs, it will take me a while, maybe 3 cranks? Then additional fuel and smoke came out the opened air cleaner.
If you have a tuner, one fix for that would be less timing advance at startup. When the engine is turning slowly enough, firing too far before the top of the piston stroke will kick the engine over backwards, momentarily turning your intake into your exhaust, and working against the starter.
Old 10-23-2014, 11:39 AM
128auto's Avatar
128auto
128auto is offline
Really? That is interesting. Where should I go? I have powervision of course, might experiment a bit.
Old 10-23-2014, 09:06 PM
dirtdobber's Avatar
dirtdobber
dirtdobber is offline
My 113 will do it if the plugs has at least 7,000 miles on em some will go 8,000. Not sure what it is because the plugs look good and brown. I replace em and it cranks like it should.
Just a thought.
doug62
07-07-2018 05:20 PM
RoamingCoastie
05-06-2018 09:53 AM
Road Star
General Topics/Tech Tips
10-11-2016 12:55 PM
shenork
04-16-2008 05:26 PM
juaniosa
EVO
14
03-15-2008 02:02 AM
Quick Reply: Starter motor recommendation
