Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
this is a question I can not figure out....
i have a '88 FLHTP, my problem is that only when the air temp is COLD, the starter does not stop cranking over the motor only when the motor does not start. This process continues even though the main power and on/off switches are both turned off when this cycle begins. The only way for the starter to stop turning over the motor is by disconnecting the battery or the motor starts. Not sure if it is the selenoid or something else. any help??
Thanks for reading and have a great day.
