Re-use neck bearings?
Old Jul 13, 2014 | 06:55 PM
WMX124's Avatar
WMX124
Default Re-use neck bearings?
Got my bike torn apart getting ready to send my fork lowers and trees to Joe at Powder Pro. I bought new neck bearings with the intention of replacing them. Unfortunately, the tools to remove and install the races are expensive (to me). Don't really want to drop the money on something I'll use once or twice. I'm wondering if anyone has left them in place and reused the bearings? My bike only has 14,000 miles. The races look decent, you can tell where the bearings spend most of their time but major damage going on.
Another option is to install new bearings in the old race. Is that possible? I'm thinking with 14k miles it's probably not a big deal to re-use but maybe you guys could help me out.
One last thing.... The lower neck bearing slid right off the triple tree stem. I thought it was going to have to be pulled off and a new one pressed on. Does that seem right?
Thanks for the help! I'll post some pictures when it's done.
Old Jul 13, 2014 | 07:19 PM
Scuba10jdl's Avatar
Scuba10jdl
At 14k, you'd be fine to leave the OEM bearings there. Just repack them with grease. As long as you don't let the front end get loose and start knocking the bearings, they should have a fairly long service life.
Old Jul 14, 2014 | 06:15 AM
WMX124's Avatar
WMX124
That's what I was thinking. They don't see much rotation. I just don't want to screw myself and have to tear it apart again anytime soon lol.
Old Jul 14, 2014 | 07:52 AM
WMX124's Avatar
WMX124
Would a slide hammer type puller work to remove the races?
Old Jul 14, 2014 | 08:30 AM
mattVA's Avatar
mattVA
I think I saw somewhere if you weld a bead on the inside of the race when it cools rapidly it shrinks and comes right out by hand. I'm not a welder but maybe you are or know someone?
Old Jul 14, 2014 | 08:45 AM
WMX124's Avatar
WMX124
I don't have access to a welder but I did read that in some other posts. Thanks for the tip!
Has anyone done this with loaner tools from advanced auto parts? I think I could get it to come out with a three prong slide hammer puller. Then maybe I could press the new races in with a bearing install tool.
Anyone?
WMX124's Avatar
WMX124
Anyone?
Old Jul 14, 2014 | 11:37 AM
WMX124's Avatar
WMX124
I was able to get the races out using a little trick i found on youtube and a big hammer lol. Now, could i just drive the new races in the frame using the old race and even taping around the perimeter to ensure it seats evenly? I was also considering just making my own bearing race tool with hardware from McMaster-carr.
Any thoughts?
Old Jul 14, 2014 | 12:28 PM
JRK5892's Avatar
JRK5892
to remove we typically cut them off, the races inside the neck will be fine if you dont want to replace those, i would replace the bearing though, simple $20
Old Jul 14, 2014 | 02:26 PM
WMX124's Avatar
WMX124
Hey Joe, the lower neck bearing on my triple tress slid right off. Does that sound right?
I've got the triple trees ready to send to you but I''m trying to get my dust seal covers off my fork lowers. I started using a screw driver and they didn't budge. I've got a brass punch on order to try to get them off. Any advise on how to get those things off?
