Hey guys ive seen a couple of dynas that have the single swing arm bag and i would like to go that route since it looks clean when done. However i can seem to find a bag that will let me keep the rear pegs. Has anyone done this or can point me in the right direction?
Here is a vendor that sells a swingarm bracket kit that supposedly will allow you to hang various bags (not included) on it and keep your pass pegs in place... bag bracket
thanks for the link, ive seen those but my problem is that i run a side mount plate and it is in the same spot. i may end up needing to break out the steel and cut and fab something up. I was hoping for a system already in place
Check out bad&g solo bags, no need to relocate anything... Been wanting to buy a bag from them
Just installed the Harley swing arm bag that I got a great deal on. You def. Can not use it with a rest peg. The bag would have to be out/away and lower on the bike so a riser bracket for the peg could be attached. The peg would have to be above or infront of the bag.. either would not work with this with this bag. Hope that helps you find or make something.
Maybe not what you're after, but I just hung a tool roll bag on the swing arm. Carries a bunch of stuff, out of the way of the rear peg. Need to have your bottom belt guard attached to keep it away from the belt though...
Yes, that's our Bobber Bracket hard mount kit. You can find more details about it on our website: www.deadcreekcycles.com
We also offer a custom top quality leather bag that works with our bracket or by itself with straps that go around the fender strut. You would have to measure to see if it would fit with your side mount license plate, but it will fit most Dynas without having to relocate rear turn signals or anything. Here is a link to info on the bag:
