Thundermax
Old Aug 9, 2014 | 11:31 PM
HHFLHR's Avatar
HHFLHR
As stated, read the instructions prior to the install and pull the ECM fuse. Also make sure you have internet access during the install, I had to update the firmeware.
Old Aug 10, 2014 | 10:34 AM
blueangel73's Avatar
blueangel73
I have really been considering this tuner for my bike, I have heard nothing but good things about it. Look forward to seeing how things go with your install.
As for that hyjacker, I am sure he is looking into some better countries to live in that will provide him with the same freedoms he has here in America, maybe he'll change his location info soon so we know where decided to move to.
Old Aug 10, 2014 | 12:23 PM
8541hog's Avatar
8541hog
The TMax is far and away the best tuner for Harley.
They offer great support should you ever need it, just spend some time with the software learning your way around. You can do it all right from the software if you ever have issues with how the bike is running.
After several thousand miles I was having some slight idle issues, ran the software, sent the info to support techs and had a new custom map back in a couple days that smoothed everything out.
Install the closest map and after you install put a couple hundred miles on the bike then run the Autotune to refine the map.
Old Aug 10, 2014 | 12:32 PM
viperpit07's Avatar
viperpit07
I've also been told some amazing things about the Tmax. i really dont want to spend anything more than i HAVE TO on a tuner. but others have convinced me its the way to go if i want to continue to add mods, so that is what my sights are set on for next spring! hope you enjoy yours!
Old Oct 7, 2014 | 05:14 PM
jws8308's Avatar
jws8308
Don't forget to use dielectric grease......it does make a difference.
