2012 dyna motor vibration is this normal ?
Old Aug 10, 2014 | 04:40 PM
Randk's Avatar
Randk
Default 2012 dyna motor vibration is this normal ?
When the motor is cold the motor shakes to the point it shakes the front fork and tire . It settles down when the engine is warm but when you ride it you can feel the vibration. The bike runs great , should i be concerned ? My warranty is up in a few months . Thanks for any advice . Checked the motor mount gap and its good
Old Aug 10, 2014 | 04:56 PM
2500hdon37s's Avatar
2500hdon37s
Normal IMO.
Old Aug 10, 2014 | 06:53 PM
CACruiserHD's Avatar
CACruiserHD
My whole freaking bike shakes and it's brand new!
maybe your motor mounts are worn or loose?? I'd start with tightening them down and see if that helps.
Old Aug 10, 2014 | 07:05 PM
103 sedona orange's Avatar
103 sedona orange
Yes, they shake. But have the dealership check it out. Do a google search about you issue. You'll get some good info about it. Good luck.
Old Aug 10, 2014 | 07:07 PM
Unbalanced Bob's Avatar
Unbalanced Bob
CACruiserHD: My whole freaking bike shakes and it's brand new!
Same here. I figure my bike is jelly, 'cause jam don't shake like that.
Old Aug 10, 2014 | 07:21 PM
chickenhauler's Avatar
chickenhauler
Check the Vibra Technics thread..... we've cured most of the "shake".
Old Aug 10, 2014 | 07:23 PM
06Sporty75's Avatar
06Sporty75
check your spark plugs as well, motors can run like crap with bad plugs.
Jaystn62's Avatar
Jaystn62
Old Aug 10, 2014 | 07:39 PM
JIMFXDC2013's Avatar
JIMFXDC2013
I think it's somewhat normal, when I start mine it's up around 1200 to 1300 RPM and settles down when hot to 900 to 1000 RPM. It's been like that since I've owned it and accept it as the way it is when I first fire it up.
Old Aug 10, 2014 | 08:20 PM
missedem's Avatar
missedem
they all shake at lower rpms and when they are cold. if it worries you take it in and ask them about it.
