Engine and Battery light on???
Old Aug 13, 2014 | 11:02 AM
luckycaribou's Avatar
luckycaribou
Default Engine and Battery light on???
Took the bike out this morning and thought I could hear some clunking noises while in second gear. Got to where I was going and let it idle for a while in neutral trying to figure out if I was hearing things or if the noise was actually coming from the bike. Nothing....
Time to leave and and I get it into second and I hear 2 loud clunks and kind of a grinding/screeching sound. Was about to pull over but only had less than a mile to go. I also noticed both the engine and battery light on.
Get home and turn the bike off. Checked both the oil and transmission fluid and both are good. Run through the diagnostic codes and come up with just the low voltage PO562 which I have had since I got the bike. (Battery tests good)
Start the bike and listen while it idles....no noise and the lights are off. Decide to ride around the block and 20 yrd in and both lights come on again but no abnormal noises while riding.
Any ideas would be appreciated. Thanks
Old Aug 13, 2014 | 11:07 AM
woodman's Avatar
woodman
Have you checked your stator?
Old Aug 13, 2014 | 11:10 AM
0lowrider1's Avatar
0lowrider1
Take off your derby cover and see if it has a burnt smell
Old Aug 13, 2014 | 11:39 AM
nevil's Avatar
nevil
Next step would be to pull the primary cover.
Old Aug 13, 2014 | 12:46 PM
luckycaribou
Draining the primary fluid as we speak. Had a few metal shavings on the plug. Maybe enough to cover half the magnet. Will pull the cover off this afternoon. What exactly should I be looking for when it's off?
Old Aug 13, 2014 | 02:36 PM
maddghost's Avatar
maddghost
If there is a bad smell like something electrical is charred you may be looking at a busted stator. Usually the engine + battery light indicates your voltage reg. is fried. But these clunk noises suggest the stator has taken a dump which would cause the same symptom = low voltage. If the battery tests good it's time right now to test the VR but the first test is the stator in your case.
If the oil has no stink find the stator -VR - battery test sequence and either perform it or have it done before you smoke the battery and save yourself 200$
PS you did not have to drain the oil out of the primary for this test. If you get the bike standing level the oil will not leak out of the derby cover. All you had to do was remove the cover and take a sniff. But since you already have did you notice a bad smell from the oil itself as it was draining?
PPS shavings from the clutch is normal.
Old Aug 13, 2014 | 03:13 PM
0lowrider1's Avatar
0lowrider1
Next step ..get a service manual.best money spent on your bike ..
Old Aug 13, 2014 | 05:08 PM
luckycaribou
Primary cover is off. No odd smells...maybe 2 copper wires off of the stator floating around in there. Been planning on doing the ipb and welding the bolts on the rotor so now is as good as time as ever I guess. Gonna tear apart tonight and hopefully get put back together next week. The noises I heard really worry me now seeing everything appears to be ok in there.
Old Aug 13, 2014 | 08:22 PM
maddghost's Avatar
maddghost
If there are wires floating around they are all that got out of the rotor, you can pull the rotor out to a certain extent and see if the stator is all broken inside. forget welding do it right and get a new kit.
Old Aug 14, 2014 | 09:38 AM
luckycaribou
Well write me down for another victim of the bolts coming out of the rotor. Now to get a parts list together to get her back up and running. Anyone that has gone through this have the part numbers handy, or a direction as to the best place to get these from? Thanks again.
Phantomas
Jul 27, 2016 06:13 AM
cchips
Aug 23, 2014 08:16 AM
skinman13
Jun 21, 2014 12:06 AM
Shortdawg72
Apr 25, 2012 09:35 PM
Cazimere
Aug 31, 2011 10:51 AM
