How did oil get here?
Old Aug 22, 2014 | 01:46 PM
HyperM3's Avatar
HyperM3
Default How did oil get here?
Ok so as Ive been riding lately Ive noticed dots of oil on my exhaust, battery bag and cover. I couldnt figure out where the oil was coming from as all my bolts for my intake were tight and stuff.
So I decided to take my intake apart to diagnose the situation. Upon removing just two of the outer bolts and letting the one part swing down, I saw this.
There was lots of oil along the edge of the acrylic on both sides. After removing the last screw and the acrylic piece there was oil dripping from the rubber of the filter. However, there was no oil ON the filter itself or inside the throttle body. All the oil was just on the edge around the acrylic.
This is confusing. How did this happen?
Old Aug 22, 2014 | 01:55 PM
soft 02's Avatar
soft 02
K&N filter? Looks like its vented to ground so thats not the issue.
Old Aug 22, 2014 | 01:58 PM
HyperM3's Avatar
HyperM3
Yeah, I originally had the breather bolts and got the spray from them. Ended up routing the bolts through hoses to the ground and that made everything much cleaner. But now I have this issue which is really weird.
Old Aug 22, 2014 | 02:02 PM
soft 02's Avatar
soft 02
Other than an over oiled air filter there is no oil in the TB.
Old Aug 22, 2014 | 02:05 PM
HyperM3's Avatar
HyperM3
Nope, no oil on the filter, not even too much from the factory. This literally just started happening in the past 100 miles. The intake has been on for the past 2500 miles.
Old Aug 22, 2014 | 02:07 PM
soft 02's Avatar
soft 02
Only thing I can figure is some fuel reversion when you shut the motor off building up on the lexan appearing to be oil.
Old Aug 22, 2014 | 02:12 PM
HyperM3's Avatar
HyperM3
Hmm, possible theory. When I shut the engine off every time I hear a "Pssht" like air blowing backwards out the filter.
Old Aug 22, 2014 | 02:29 PM
Hurricane19's Avatar
Hurricane19
My bike will do this as well sometimes, never could figure out why.
Old Aug 22, 2014 | 02:39 PM
jaxdwg's Avatar
jaxdwg
My crankcase breather tubes, into the back of the filter, use to do this. I started running the bike 1/3 qt lower and it stopped doing that. It worked for me.
Old Aug 22, 2014 | 02:44 PM
HyperM3's Avatar
HyperM3
Yeah but I routed my breather bolts into hoses down to the bottom of the bike(can barely see in the picture). They aren't routed back into the filter.
