Daymaker Questions
Old Aug 25, 2014 | 03:18 PM
jangler14's Avatar
jangler14
I replaced my stock bulb with a brighter blue option for about 40 bucks and that seemed to help some at night, though LED lights are wicked bright and a much better option.
Old Aug 25, 2014 | 10:11 PM
fatmanontwowheels's Avatar
fatmanontwowheels
I am interested in the daymaker also, but is the replacement bucket really needed?
Old Aug 26, 2014 | 06:10 AM
06Sporty75's Avatar
06Sporty75
Originally Posted by PanHeadRich
I'm curious as to how long you've been using that bulb? I had a 90/100 watt in the past that that was used in a 5.75" Springer bucket. It burned, discolored & deformed the H4 connector & wiring in the bucket. The connector was damaged enough from the heat that it had to be replaced.
yeah, I had a blue light installed or less than a day and it already stared meting my connector on my 03, , the newer connectors are better & can take the heat but even still those high power bulbs will still cause the reflectors to be coated with a black haze after a year or 2.
Old Aug 26, 2014 | 05:42 PM
Puglia10's Avatar
Puglia10
I went from stock, to HID, to day maker.
The HID is only a slight improvement over stock (price shows that. the light is scattered, not very usable, but it is brighter)
The Daymaker is a HUGE difference (price shows that) Definitely worth it IMO.
$320 from Kutter HD online.
Only drawback is the harsh cutoff line makes you lose some light if you're leaning over hard, but i'd still buy it again.
Old Aug 26, 2014 | 07:04 PM
missedem's Avatar
missedem
I was told by the harley shop that yes you have to buy the new headlight bucket with an LED light on the dyna models..
Old Aug 26, 2014 | 07:46 PM
RANGER73's Avatar
RANGER73
Are we talking 5 3/4" or 7"? I needed a Springer bucket to do the Daymaker on my Softail. The stock shallow bucket wouldn't accommodate the back of the 5 3/4" bulb.
I had the 7" TL7 on, in a 7" Fatboy bucket (not OEM) and it snapped the bucket ears. But it too is a great light. And only $189.
Old Aug 26, 2014 | 09:32 PM
fatmanontwowheels
That why I was asking. It made sense to me because of the heat sink on the back of the daymaker, but no one would confirm that. That's why I was skeptical. Some on here say yes and some say no.
Old Aug 26, 2014 | 09:36 PM
fatmanontwowheels
5 3/4, at least I am.
Old Aug 26, 2014 | 10:05 PM
loopie's Avatar
loopie
just put a plus 90 globe in, at $20 bucks a cheaper better light, being the same 55/60 there's no stress on your plug...
and spend the savings on some spot lights if then required
Old Aug 27, 2014 | 06:42 AM
Ninety8NeonACR's Avatar
Ninety8NeonACR
I've had it in for at least 3000 miles and I haven't noticed any problems so far. I haven't checked the wiring or connector inside the bucket though either.
