2001 FXDXT Carb Frustration!!!!!
I started from scratch. 96 Street Bob - EFI. Converted to CV 40 - from a 92 Evo Softail.
REPLACE that DYNOJUNK slide, NEEDLE, and Spring with stock parts. That stuff is garbage, and is your problem. Order a CVP stock replacement slide, spring, the CVP emulsion tube, and either their velocity needle or N65C needle, mine as well get the nice idle screw, and fuel screw, with packing kit as well. The carb will work properly after these parts are installed.
I would also like to say that if you cant get a CV carb running correctly I would HIGHLY recommend avoiding a Mikuni HSR42, because you need to master CV carb tuning before you ever try and tune a HSR carb. The HSR carb is a much better carb due to unlimited adjustments, and for the same reason will confuse someone that doesnt have a firm grasp on tuning carbs like the Keihin FCR or Mik HSR carbs.
Get a service manual, disassemble your carb, post pics, and let everyone guide you on the steps to take during assembly. The CV carbs are great carbs and run better than a poorly tuned HSR all day.
Screamin Eagle Air Intake,
S&S 510 Gear drive cams,
Thunderheader
Sea Level, High Humidity Levels, and Temds over 80f all the time.
45 Pilot,
Float Level set exactly in the middle of the spec.
195 Main
N65C Needle NO shims
Slide drilled to 5/64
Stock Slide Spring
3 Turns Out on fuel screw
I would also like to note that the fuel screw seems to carry over much farther into the pilot circuit then I have ever experienced with any other carb. This may be attributed to a fairly small single carb on a large displacement engine.
I installed the 48 Pilot, reset fuel screw to the 1.5 turns out as it was from the factory. 90F Temp 70% Humidity. Primed the fuel valve with a vacuum pump, and fired the bike.
Took about 15 seconds on choke, then about 10 seconds on high idle using the cruise control. Then it would idle well on its own, and would lumpy idle for a few minutes. I went riding and seemed to catch every stop light, eventually my idle ended up at 1300 which is a tad high so I stopped and gave the idle screw a slight adjustment. This may have been due to the fact that I switched to SAE 50 wt oil because its always so hot here, and the oil took much longer to thin out. Rode for another 5 miles and the idle again seemed to hover at 1300 so I gave it another slight adjustment. I may loosen the fuel mixture screw another 1/4 of a turn if my idle doesnt stay at the 1200 RPM that I prefer. Hot starts, just hit the button, dont touch the throttle and the bike goes to a nice solid idle.
