Wide Tire Kit issue settled!
Old Apr 9, 2007 | 11:49 PM
DougsDyna's Avatar
DougsDyna
Default RE: Wide Tire Kit issue settled!
This is why the GT502 exist at all.............. It was very specifically designed for a 4.5" rim as I have stated over and over again when the 180 thing comes up in the Dyna forum.
The below information is DIRECTLY from the Dunlop MC tire website.
As far as I have found, Dunlop is the ONLY manufacturer that has a 180/60B17 bias made specifically for a 4.5" rim (as on the 06/07 Dyna).
As you can see the GT502 was made for the 2004 FXSTDSE2. It is a Screamin Eagle part.
1 of a kind....................... I think it would be safe to use on a Dyna, any 06/07 Dyna.
Not sayin it is any better than any other manufactures tire.
I have stuck with the 160 series.Running a Metz at the moment.
DougJ (not Bob)
Make: Harley-Davidson | Model: FXSTDSE2 (04) - Screamin? Eagle Softail Deuce Front Rim Size: 2.15x21|Rear Rim Size: 4.50x17
Recommended Front Tire:
Tire : D402F |Size : MH90-21|PSI/Loaded : 30
Recommended Rear Tire:
Tire : GT502** |Size : 180/60B17|PSI Rear/Loaded : 36/40
O.E. Replacement Front Tire:
O.E. Replacement Rear Tire:
Old Apr 10, 2007 | 01:14 AM
tireater's Avatar
tireater
I RUN A BIASED 140 ON THE FRONT AND A RADIAL 180 ON BACK - NO PROBLEMS - SPOKED RIMS..
aklim156581
Apr 28, 2017 11:34 PM
floridian46
Sep 24, 2007 05:56 PM
stubby
Oct 24, 2006 12:45 AM
fl_799
May 3, 2006 03:14 PM
