Need welding tip
Old Sep 30, 2014 | 11:41 AM
sonnydaze's Avatar
sonnydaze
I guess I should tell you why I would not weld nut on . 1st a nut has grades of hardness 2nd a nut deforms when welding so often times you deform the threads and hole so you have to use a bottom tap to clean threads but now you've hardened nut and your taping a blind hole , its easier to use cold roll or piece of mild steel then drill thru and tap after welding and yes a mig will do the work you need no need for tig
jqb12
Oct 15, 2016 10:02 AM
katanaplanet
Sep 5, 2014 11:52 PM
GlobeWarmer
Aug 12, 2013 02:02 PM
gbakman
Aug 15, 2011 03:36 PM
PoBoyGlide
Feb 11, 2008 11:44 AM
