Fits '02-'03 XL, '02-later Dyna® (except FXDXT and '09 FXDB), and '02-later Softail® (except FXSTD/I) models with stock bullet-style turn signals. (NOTE: Not intended for use on '04-later FLHX, FLHRS, FLTR, FLHTCSE models, '05-later FLSTN models or models equipped with Bullet Turn Signal Bar Kit P/N 68615-04 or 68617-04. If installed on these models the system will function properly but will not meet the DOT minimum separation requirement for a red tail light to red turn signal.)
Turn signal module adds an auxiliary brake light and running light function to your existing turn signals for auxiliary rear lighting. Red lenses glow when the headlamp is on, and increase in intensity when brakes or turn signals are activated. Easy-to-install, the kit simply plugs into your existing wiring harness. Red turn signal lenses are included. Meets DOT requirements.
