Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I have an 09 FLTR. Bought the SE tuner, cable and software. Downloaded updates for both VCI and software. Pre-loaded is a MAP that would suit my purpose (205TD003, SE hi flo air filter, race exhaust, 1580). I attempted to reprogram the ECM, but it showed "File not compatible with ECM". Any suggestions would be helpful....thx all!
hawg3,
By software, are you talking about the cd 32111-09, if so how many maps or calibrations for the 09 bikes are on the disc? Any idea if they are the same as the ones the dealers download? I am thinking about buying supertuner and software instead of dealer download then I would have supertuner in case I ever need to dyno the bike I would already have it.
nafarmboy
hawg3,
nafarmboy
The TTST is much better than the Super Tuner.... www.mastertune.net
I give forum members a 10% discount on this unit.
There is no "Super SERT". But the only advantage the Super Tuner has over TTS is that the SEST can datalog all on it's own with no computer hooked up, with the datalogs transferable to a computer later on.
The TTS tuner is the old SERT with a couple of new twists. It has more features and can modify more settings. It has newer maps which can be used in conjunction with special datalogs to generate accurate VE tables on, or off, a dyno. It's the cat's meow. Really.
So looking at both units I saw where the TTS has maps for downloads, is there any for the 09 touring bikes yet. Looking at the names of the files how can i tell which one of the canned maps will work best. Also is the best place to buy direct from TTS?
When the TTS can do it's own stand alone data logging or the SEST software can generate it's own accurate VE tables, then you will have a true cat's meow. Other than that, they both have useful features and each one has it's own advantages and disadvantages. JMO. Later, Calvin.
