engine code P1358
Old Dec 13, 2010 | 02:29 PM
fiddledicksr's Avatar
fiddledicksr
Default engine code P1358
I keep getting an engine code p1358 can any one tell me what could be causing this code on the rear EFI.
Old Dec 13, 2010 | 03:01 PM
evil-1's Avatar
evil-1
Here's somethin I found, maybe it will help. This was in a post about the p1358 code.
My '04 Ultra used to throw the same codes. Dealer told me that I was not holding the starter button down long enough after a 'heat soak' re-start and a slight kickback was the problem. Well, that fixed my problem, seems I remembered doin that once or twice after a long hot ride. Also I read somewhere in this forum that too much anti-sieze on the plug threads messes up the ground path and the coil / ion sensor sends the signal to store the code in the ecm. Anyway, no more codes for me...ere's somethin I found, maybe it will help.
SPARKY01
May 14, 2011 08:25 AM
shortride
Oct 4, 2010 09:57 AM
in the wind-Murrells Inlet, SC
Jul 21, 2010 09:31 AM
Bubba Zanetti
Aug 27, 2008 12:14 PM
raylikesbeer
Jan 30, 2008 09:22 AM
