Twin cam - kills the ignition when trying to engage the starter?
Old Oct 26, 2014 | 10:12 AM
Peter Panhead's Avatar
Peter Panhead
5th Gear
Default Twin cam - kills the ignition when trying to engage the starter?
Hello - Denmark is calling.
Just experienced my Fatboy/1999 with Twincam engine. When engaging the starter button, all I hear is a "click" and ignition lamps goes black..
Checked the fusebox - all good. Checked the ignition switch - all good. All the wiring seems to be OK.
Is there some kind of thermofuse connected to the starter?
Your help is very much appreciated.
Peter
Old Oct 26, 2014 | 01:35 PM
cficole's Avatar
cficole
How's the battery?
Old Oct 26, 2014 | 02:44 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Are you saying the starter does not crank when you press the start button?
It sounds like a weak battery or a poor electrical connection.
First check the cheap and easy stuff...
Make sure the battery is fully charged, and have a shop load test it (in the states, an auto parts store will do this for free).
Make sure all the battery connections are clean and secure (the cable from the battery to the solenoid, the cable from the solenoid to the starter motor, and the ground cable at the battery and frame).
There is no fuse on the starter circuit on any vehicle. Way too much current passing through the circuit.
gelbm3
Dec 13, 2015 06:03 PM
sportyfrahm76
May 31, 2012 01:10 AM
Mike Chrosniak
Electrical/Lighting/Alarm
Mar 4, 2012 08:35 AM
vetto
Feb 26, 2010 05:29 PM
PJsthnam
Mar 29, 2006 05:33 AM
