Fast signal blinking on console.
Old Dec 25, 2014 | 09:35 PM
sdeck86's Avatar
sdeck86
Default Fast signal blinking on console.
Hello fellow Harley people,
I've recently upgraded all of my lights to H-D LED lighting. First I had auxiliary mirrors with turn signals installed, which required a load equalizer for proper functionality. The rear turn signals were the last lights I replaced. The description for the LED turn signals on the Harley Davidson website indicate that installation does not require a "control box" or a load equalizer.
After completing the install I inspected everything and the signals all work perfectly. However, the next day I noticed that when signaling the console signals flash very quickly. Everything is functioning normally, everything except for the console indicators. As a sanity check I decided to go ahead and buy a load equalizer anyway. After installing the load equalizer, however, there was no change. Lighting everywhere functions normally except for the fast turn signal indicators on the console.
I spoke to a Harley technician and was basically told that if everything is working fine then to keep an eye on it and bring it in if anything changes. I'm not totally satisfied with that answer. Do any electrical gurus here know what is going on?
Please and thank you!
Old Dec 25, 2014 | 09:52 PM
willryder's Avatar
willryder
I've recently upgraded all of my lights to H-D LED lighting. Initially, I had the auxiliary mirrors with turn signals and the Daymaker headlamp installed, which required a load equalizer for proper functionality. Replacing the tail lamp was simple enough, and the rear turn signals were the last lights I replaced. The description for the LED turn signals on the Harley Davidson website indicate that installation does not require a "control box" or a load equalizer.
After completing the install I inspected everything and the signals all work perfectly. However, the next day I noticed that when signaling, the console signals flash very quickly, indicating something is wrong. Again, I inspected my turn signals and lighting everywhere and everything is functioning completely normally, everything except for the console indicators. As a sanity check I decided to go ahead and buy a load equalizer anyway. After installing the load equalizer, however, there was no change whatsoever. Lighting everywhere functions normally except for the fast turn signal indicators on the console.
I had the same problem when i installed my led turn signals and read the instructions and it said to run the 4 way hazards for 5 minutes to re-sync the CanBus system.That did the trick for me hope that works for you.
Old Dec 27, 2014 | 12:55 AM
sdeck86's Avatar
sdeck86
That did it! I must have overlooked those directions when I did the install. I appreciate it. Quick and easy solution.
Old Dec 27, 2014 | 01:24 AM
willryder's Avatar
willryder
Cool!! glad to hear that did it.
Old Dec 27, 2014 | 02:20 AM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Great advice...not many HD dealerships know to do this. Same thing happened with me...and they basically told me to live with it. lol
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Dec 27, 2014 | 12:24 PM
willryder's Avatar
willryder
Thanks! yeah i wonder about the dealerships sometimes. That's why i try and do everything possible that i can do myself before i will take it to them.
Old Dec 29, 2014 | 02:26 AM
Deguello68's Avatar
Deguello68
THIS is why I really like this forum, most are so helpful. I love that Red willryder.
Old Dec 30, 2014 | 07:34 PM
willryder's Avatar
willryder
Thumbs up
Thank you!
Old Feb 4, 2015 | 10:38 AM
sdeck86's Avatar
sdeck86
I have a follow up question with the rear H-D LEDs if anyone knows. From time to time, the console signals begin blinking fast after miles and miles of normal functioning. The rear LEDs stop working entirely, and it isn't until I turn the bike off and on again that everything is restored to how it should be.
Thoughts?
Old Feb 22, 2015 | 04:57 AM
sdeck86's Avatar
sdeck86
Default Sorted
Finally got this sorted out. I took it into Harley yesterday morning and had a return call 20 minutes later. They never really gave me an exact description of my error codes, other than to say the BCM was having issues communicating with my rear signals. They tried installing a rear load equalizer, but it caused even more signal dysfunction. Ultimately, they decided there is a compatibility issue with newer bikes and LEDs.
We decided to try tricking the BCM into functioning normally by installing stock incandescent lights on my forks. I've read about people doing this to correct signal problems. Today my girlfriend found several photos of LED/incandescent combos that are almost my exact setup. Two hours later my error codes were gone and all SIX signals worked perfectly. Parker, the SLC Harley manager told me he "puts out the fires" and charged me absolutely nothing for their work (which included fork mount parts).
I had issues with these signals for months and did a good amount of research to try and solve the problem. Once again, the Harley dealership came through and my bike is at 100% again. Hopefully, this may be helpful for anyone else having LED problems.
