Bike turning on without pressing start button
Old Jul 6, 2018 | 09:30 PM
Vernal's Avatar
Vernal
Originally Posted by Spare
Did you ever fix this issue? What was actually wrong?
see post 6 I think Dan nailed it.
Old Nov 5, 2019 | 03:22 PM
McKishen's Avatar
McKishen
6th Gear
It does not sound like a stuck starter relay.
If the start relay sticks in the on position, the starter will crank as soon as the ignition is turned on, and it will not stop cranking until the ignition switch is turned off (on this model bike).
Symptom (without pushing the start button):
Turn on ignition switch and kill switch.
If the transmission is in neutral, the starter will crank.
If the transmission is in gear, starter will not crank, but pulling in the clutch lever causes the starter to crank.
This means...
Everything is working correctly....except the starter switch, it is sticking in the on position.
Guys, you’re referring to the switch in the handlebar controls, right? Anyone have part numbers?
Old Nov 5, 2019 | 03:39 PM
Spare's Avatar
Spare
6th Gear
Default Part number
70239-07 this is the part number for all of your hand control buttons through Harley. Yes I was speaking of the start button on handle bars
Old Nov 5, 2019 | 04:05 PM
1of2's Avatar
1of2
"Moderator"
This means...
He said the previous owner installed a start switch at the solenoid. My money is on this. Get rid of it and get rid of the problem.
Old Nov 5, 2019 | 05:49 PM
McKishen's Avatar
McKishen
6th Gear
mom, thanks!
Old Nov 12, 2019 | 09:55 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
We`ll never know what caused the issue because the OP never posted a follow up, probably traded the bike in for bowling ball and shoes...
If the solenoid was stuck in the on position, the starter would crank no matter what position any switch was in.
You lose your money...
Old Nov 13, 2019 | 09:57 AM
LQQK_OUT's Avatar
LQQK_OUT
I had the same problem a few years ago. Replacing the Run/Stop/Start switch fixed the issue.
Here is the thread.
https://www.hdforums.com/forum/touri...rt-button.html
Old Apr 22, 2022 | 05:06 PM
Fish7's Avatar
Fish7
Stage II
This means...
My starter is engaging while running. It also erratically starts by itself when in neutral. Doesn't start when the bike is in gear whether or not the clutch is in.
Any ideas?
Old Apr 22, 2022 | 05:13 PM
MURPHCC1's Avatar
MURPHCC1
Welcome aboard from Old Cape Cod!!
Old Apr 22, 2022 | 09:30 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Originally Posted by Fish7
Any ideas?
Doesn`t the post you quoted pretty much explain all there is to know???
