Doesn`t the post you quoted pretty much explain all there is to know???
08, 883
Cleaned the fuse box, swapped relays, took it for a ride but the starter, started engaging. Tested again and it started in neutral, didn't start in gear, did start in gear with clutch in. Ordered a starter switch, I'll post the results. Thanks!
