Help at start up
Old Feb 25, 2010 | 05:38 PM
Bearcat1's Avatar
Bearcat1
Default Help at start up
Could anyone give me the particulars on whats happening when you hit the start switch and the bike doesn't start up and instead you hear an awful grinding like sound (the starter I assume)? Usually fires the second time around. Seems to be happening more with my bike as of late. Can't be good for it.
Thnx
Old Feb 25, 2010 | 05:42 PM
Badfinger's Avatar
Badfinger
Wow, could be several things like a loose starter, bad gear, loose or corroded wire. See your dealer.
Old Feb 25, 2010 | 06:39 PM
Bearcat1's Avatar
Bearcat1
Yes, I think I'll take you up on that. Sumtin doesn't seem right.
dawg's Avatar
dawg
Starter clutch?
Old Feb 25, 2010 | 06:42 PM
JimTJr's Avatar
JimTJr
Are you under warranty? Because it sounds like your starter has teeth messed up, Or the gear in the motor it engages with.
I wouldn't keep messing with it, get it repaired. It will only get worse of course.
Old Feb 25, 2010 | 07:14 PM
honestbob's Avatar
honestbob
Got mine out of the shop Last week for the same thing. It would not do it everytime but Usually when hot. I thought it was the starter but it turned out to be a bad compensator. The had to replace the compensator and rotor. Glad it was under warranty. The service manager said it has been an ongoing problem with 06-08 models It started at around 40,000 miles on my 08 FLHT.
Old Feb 25, 2010 | 08:53 PM
Bearcat1's Avatar
Bearcat1
Yes, still under warranty. I'm going to try to bring it in tomorrow morning if I can dodge the rain. Not something to playing around for sure. Thanks.
Old Feb 26, 2010 | 03:42 AM
scatpac1's Avatar
scatpac1
Wink
Yep, no good stock compensator, you need the s/e compensator installed, they should cover it under warranty. good luck.
Old Feb 26, 2010 | 05:10 AM
smokindave's Avatar
smokindave
Get the SE compensator and never have the starting issue again.
Old Feb 26, 2010 | 07:14 AM
dog155's Avatar
dog155
Starter bendix is the culprit!
