DIY need help, changing Nacelle headlight.
Old Apr 4, 2015 | 04:09 PM
WarCamel's Avatar
WarCamel
6th Gear
Default DIY need help, changing Nacelle headlight.
Hey Guys,
I'm trying to change my current headlight on my 01 Fatboy. I have a Nacelle headlight and I"m looking to change the glass. I've taken off the outer ring, but when I get to this inner ring I'm stumped.
This is the headlamp I'm installing.
this is what it looked like before I took out the outer ring.
I undid this bottom screw (pictured below)
All I see is a rubber gasket. But this inner ring can be rotated with some effort. Does this ring rotate? There are no screws to undo, only a rubber seal as you can see in the pic.
these little holes where normally screws are located are covered by a rubber gasket.
Any advice is appreciated. I used youtube, the service manual and google but couldn't find much.
fat bastard 68
EVO
Jan 5, 2014 07:47 AM
camo36
Nov 11, 2010 07:21 PM
wooosaa
May 12, 2009 10:29 AM
DarkManC
Jan 23, 2009 08:16 AM
traveler
Product Reviews
Jun 26, 2005 12:37 PM
