Right turn signals dead
Old Apr 20, 2015 | 01:36 PM
Chriscruiser's Avatar
Chriscruiser
Question Right turn signals dead
Tricky fault. Have a 2007 Streetbob and everything worked fine till two days ago. Both front and rear RIGHT turn signals as well as the console right indicator won't work. Could this be the switch? Where do I start looking? Also, they don't flash when alarm is activated. This makes me think it's not switch-related? (Regular incandescent bulbs, not LED)
Old Apr 20, 2015 | 01:51 PM
103 sedona orange's Avatar
103 sedona orange
I'd start with the bulbs. I replaced one the other day that was not making contact. It would work off & on. Let's know what solved your problem. That's how we learn. Good luck.
Old Apr 20, 2015 | 02:02 PM
Chriscruiser
Thanks Sedona Orange. Will give it a try��Nothing to lose...
Old Apr 22, 2015 | 02:31 AM
Chriscruiser
Default Found the solution
Well, retracing my own recent work, I found the fault.
In attaching a sissy bar to my bike on the weekend, I inadvertently pinched the turn signal wire between the nut and the rear fender, when replacing the mudguard. Wire was stripped and grounding on the mudguard. Almost always, retrace the steps of the "master of disaster" (aka "me", the aspiring technician) and you are sure to find the new bug in the system...👍
freebird26570
Electrical/Lighting/Alarm
Jan 20, 2015 05:00 PM
ws6lvr
Mar 22, 2013 03:04 PM
WARG
Mar 21, 2011 09:53 AM
michaelbarry
May 22, 2007 07:50 PM
Talent Scouter
Sep 1, 2006 09:20 PM
