Custom dynamics front signal install
Old Jul 12, 2015 | 04:38 PM
akodust's Avatar
akodust
Default Custom dynamics front signal install
Do you need a load eq for the front, if I have one on the back. If I put load eq in the main wiring harness for the rear...is that all I need.? Or do I need 2 load eq's....thanks for your help😅
Old Jul 13, 2015 | 02:23 PM
enodrano's Avatar
enodrano
No you do not need a second load equalizer. The only catch is you have to have the load equalizer before the run/turn/brake module in the rear harness. If your rear turn signals do not have run/turn/brake functionality then you have nothing to worry about. You will know if it's in the wrong place if your turn signals start to hyper-flash.
Old Jul 14, 2015 | 01:27 PM
akodust's Avatar
akodust
Thanks for your help...I think the load eq plugs in under my seat...seems like an easy install...custom dynamics 1156 & 1157 + Kuryakun alarm compatible load eq...what do you think?
Old Jul 15, 2015 | 08:22 AM
t100rc's Avatar
t100rc
Take the 4 minutes to install them and see whether they behave properly.
rgilkerson
Electrical/Lighting/Alarm
Mar 22, 2020 09:13 PM
nchapa
Jan 12, 2017 04:40 PM
jumpinjoe313
Jan 27, 2016 06:23 PM
Scooter68
Apr 3, 2015 11:56 AM
SBW Cycles
Aug 13, 2011 03:10 PM
