Strange issue
Old Aug 8, 2015 | 02:43 AM
Jonnys's Avatar
Jonnys
6th Gear
Default Strange issue
i ride a 98 dyna superglide i went on a trip today parked bike at destination walked out to bike battery 100% dead jumped bike worked fine goto gas station before heading home shut it off like a dum *** and needed another jump i get on the road headlight burns out ok so i switch to brights bam they go then blinkers speedo light and all lights out and bike starts chugging and not wanting to accelerate every now and then i would hear a clicking sound then it would accelerate then next thing i know finally stalls out on me any ideas?
Old Aug 8, 2015 | 06:45 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
There is nothing strange about it, this is what happens when you have no electrical power.
If a battery goes dead while you are riding it, it usually means the charging system has failed.
Charge the battery and have it load tested.
Perform a charging system check on the bike.
Old Aug 8, 2015 | 11:45 AM
Jonnys's Avatar
Jonnys
6th Gear
thanks dan ill do that
Old Aug 8, 2015 | 12:14 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Let us know what you find out.
Old Aug 10, 2015 | 04:40 PM
Jonnys's Avatar
Jonnys
6th Gear
new battery all hooked up power comes on now bike wont roll over
Old Aug 10, 2015 | 05:41 PM
Jonnys's Avatar
Jonnys
6th Gear
going to check all the fuses etc
Old Aug 11, 2015 | 03:57 PM
Jonnys's Avatar
Jonnys
6th Gear
fuses are fine but i noticed none of my lights work and i pulled the plugs and am getting no spark not quite sure where to go from here
Old Aug 11, 2015 | 04:37 PM
Dan89FLSTC's Avatar
Dan89FLSTC
First you said it won`t roll over, then you said no spark, I`m confused...
What exactly is working, and what is not working.
Will the starter crank the engine?
Old Aug 11, 2015 | 05:50 PM
Jonnys's Avatar
Jonnys
6th Gear
yes its cranking sorry for the misuse of the term its cranking just not starting no spark
Old Aug 11, 2015 | 05:55 PM
Jonnys's Avatar
Jonnys
6th Gear
my indicator bar is working like where it shows neutral and blinkers n oil etc headlight doesnt work blinkers dont work tail light doesnt work and no spark
