Electrical help please
Old Sep 21, 2015 | 06:51 PM
PSCarter's Avatar
PSCarter
Stage III
Default Electrical help please
I have an 03 Heritage and while I was riding my speedo, turn signals and brake lights stopped working. I looked at connections on my battery and everything is good. Tonight I went to further investigate and when I turned ignition on everything worked until I squeezed my front breaks. It went out then came back on. Tried it a few more times and the same thing until it stopped coming on. Could this be the VSS or something else. Thank you in advance for any help.
Old Sep 21, 2015 | 07:02 PM
QC's Avatar
QC
<p>Sounds like the front brake switch may be causing a short. The little button switch that is just inside the switch housing.</p>
Old Sep 21, 2015 | 07:18 PM
PSCarter's Avatar
PSCarter
Stage III
Ok. I'll check that out. Thanks
Old Sep 22, 2015 | 08:28 AM
PSCarter's Avatar
PSCarter
Stage III
ok, this morning I did a little more trouble shooting kinda... I turned on the ignition and everything was normal so I tried the foot brake and the same thing happened, I lost the backlight on speedometer and odometer went out and turn signals wouldn't work. turned if off and back on and everything was normal. I turned on turn signal and hit foot brake and everything went out and I couldn't turn off my turn signal.. Is this a relay of some sort causing my headache??
Creiter1990
Jun 29, 2013 04:54 AM
CasaWolves
Sep 22, 2010 10:31 AM
MoonCricket
Feb 27, 2010 09:14 AM
SamStone
Jun 25, 2006 08:22 PM
sambalie
General Topics/Tech Tips
Jun 5, 2006 12:02 AM
